Rough idle please help
Discussion in '4 Cylinder' started by TacomaTyler_2002, Dec 13, 2019.
  1. Jan 25, 2020 at 9:16 PM
    zooma-loom
    zooma-loom Well-Known Member
    RIGHT out of sight of SCOTTSDALE, AZ
    1997 Tacoma, Ext Cab, 4x4, 3RZ, A/T, Manual locking hubs
    The motor mounts are the number 1 item that is overlooked. If you have a 4 cylinder with over 60,000 miles you will be amazed when you replace the motor mounts. You still must check the obvious things, (plugs, wires, cleaning MAF, check for vacuum leaks, etc) but don't start replacing expensive parts, do the mounts, not that expensive and money well spent. It is not normal to have a severe vibration on the 3RZ & you do not have to live with it. You can thank me later :thumbsup:
