Rough idle/power loss
Discussion in '1st Gen. Tacomas (1995-2004)' started by Klepto, Jul 27, 2010.
  1. Jul 27, 2010 at 3:08 AM
    Klepto
    Klepto [OP] New Member
    Shawn
    Lafayette,La
    Prerunner SR5 6 Cyl
    I have an 04,6 cyl,automatic with roughly 111k miles.
    About a month ago I started seeing the only performance issues Ive ever had since I rolled it off the lot.
    It started with a rougher idle than usual and within a couple weeks developed some periodic power loss while driving,usually at lower speeds and sometimes while at highway speed.
    After replacing fuel filter,plugs/wires and air filter,much of the problem has been alleviated.In fact,after the air filter it completely stopped for about a week before returning with similar symptoms,though not nearly as bad.
    At this point of course Im considering moving on to the distributor,and really not wanting to tackle the fuel pump as Im sure its probably in-tank as most are these days.
    Just needed some input from someone whos possibly had this issue,or could offer anything before I sink more money into chasing down the problem.
    Thanks!
  2. Jul 27, 2010 at 3:24 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Sounds like your Air Idle Control Valve. Happened to mine, also could be a Vacuum Leak
  3. Jul 27, 2010 at 5:13 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    A stretched timing belt can do this too.
