Rough idle?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USNavyTaco, Apr 14, 2011.
  1. Apr 14, 2011 at 12:19 PM
    USNavyTaco
    USNavyTaco [OP] Well-Known Member
    Goose Creek SC
    06 Tacoma prerunner sr5 with mods
    2 inch coil spacers up front, tsb rear, Kobalt toolbox, westin bull bar, driver seat height mod, jvc head unit, rag joint zip tie truss mod, 17inch alloy 4runner sr5 rims wrapped in 265 yoko geolanders, off road lights, uhaul hitch, tacoma seat covers, avs vent visors, debadged prerunner, mud flaps gone, scanguage II, glovebox shock absorber mod,flowmaster 40 exhaust,
    My 06 Tacoma v6 seems to have a shake when in park, not in drive. The shake is not constant. Seems to fluctuate between a vibration and a shimmy. Opened engine bay, and visibly saw engine cover and oil cap shaking. 46,000 miles on it. Just wondering if this vibration is normal for the 4.0 L v-6? If not, what can be done about it? rpm's are normal as well
  2. Apr 14, 2011 at 3:03 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    check out the "similar threads" that are located at the bottom of this thread...good starting point
  3. Apr 14, 2011 at 3:04 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i notice some roughness here and there...i noticed less of a roughness when i put in my new fuel pump and fuel system cleaners seem to keep the engine running fairly smooth
  4. Apr 14, 2011 at 4:50 PM
    USNavyTaco
    Goose Creek SC
    I'll look for chevron techron. Any brands to stay away from?(stp?)
    Also, I'm getting new plugs, tb cleaned within next 3000 miles
  5. Apr 14, 2011 at 5:43 PM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i usually go with the lucas fuel system treatment
  6. Apr 14, 2011 at 8:10 PM
    USNavyTaco
    Goose Creek SC
    Just a thought, if the fuel injector cleaner does not solve this. Could it be caused by something more serious?
    Vaccuum leak? Engine/Tranny Mounts?
    I thought it may be a vaccuum leak, but wouldn't I experience a high idle speed?
    and engine mounts and tranny mounts, wouldnt i experience nasty vibrations all the time?
  7. Apr 14, 2011 at 9:42 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    The rough idle can be caused by a number of things, from a loose splug, dirty MAF, dirty airfilter, bad coil, bad gas, etc.
    It might be worth it to, dare I say it? have a mechanic run a diagnostic... just find out what it is, then fix it yourself; no point in replacing perfectly funtioning items while hunting down the problem.
  8. Apr 14, 2011 at 9:53 PM
    USNavyTaco
    Goose Creek SC
    Already checked airfilter.
    I'll start with the cheap repair possibilities. First thing I'll do is add a bottle of fuel injector cleaner next time I fill up the tank (probably Wednesday). If that doesn't fix it. I'll live with it till next oil change, when I'm due for new spark plugs and a throttle body cleaning anyway. If it still idles rough, I'll have a diagnostic run. But this could simply be a bad tank of gas anyway. So I won't jump to any expensive conclusions. Also, as long as it's not getting worse, I won't worry about it too much till tune up time comes.
  9. Apr 14, 2011 at 9:56 PM
    nvdeserted
    Reno, NV
    Are you driving alot of dirty/dusty conditions? or is stuff staying pretty clean?
    the reason I ask is because if it's dust related, that'll help narrow it down; similarly, if you're not eating dust, then that can help rule out some possibilities too.
  10. Apr 14, 2011 at 10:12 PM
    USNavyTaco
    Goose Creek SC
    Staying on road.
  11. Apr 14, 2011 at 10:15 PM
    nvdeserted
    Reno, NV
    In that case I'd focus first on fuel, injectors, throttle body, coil, plugs (not necessarily in that order)
  12. Apr 14, 2011 at 10:24 PM
    USNavyTaco
    Goose Creek SC
    Yes that was my general plan. In search of a potential problem today, I just discovered how long the tacomas oil dip stick was. The thing is like 5 feet long!
