Rough idle
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dberneski, Mar 3, 2024.
  1. Mar 3, 2024 at 6:05 PM
    Dberneski
    Dberneski [OP] Member
    David
    2020 Cement trd off-road taco
    Tonneau cover, running boards, interior led kit, ridge grapplers 265/75/16
    I have a 2020 Off-road 2wd. I was on vacation recently in northern Georgia through the mountains. When we got back home to Florida today, I noticed it was idling rough. Driving at highway speeds, the truck had low power. I plugged in my obd reader and car scanner pro app. The obd-2 said no dtc’s were found, great news, but the ecu 2, 100 dtc’s were found. I find this hard to believe but I guess it’s possible. Anyone have any issues like this?
  2. Mar 4, 2024 at 4:14 AM
    Dberneski
    David
    I guess I read the scanner pro app wrong. The truck didn’t throw any codes whatsoever
  3. Mar 4, 2024 at 4:27 AM
    OkieTom
    OkieTom Member
    White 2020 SR5
    Is it possible you got some 'bad' gas during your trip?
  4. Mar 4, 2024 at 7:10 AM
    Leomania
    Leomania Well-Known Member
    Leo
    2011 Tacoma TRD Sport DCLB v6 4x4
    All stock, baby!
    The easiest first step is to clean your mass airflow sensor (MAF). Unplug your battery before doing this, make sure to use MAF cleaner (no substitutes), then, after reconnecting the battery, expect the ECU to take a few minutes to determine what the correct idle is.
    How long has it been since the plugs were changed?
  5. Mar 4, 2024 at 7:22 AM
    Dustrider
    Dustrider Well-Known Member
    Dave
    Hillsboro Oregon
    98 Tacoma 4x4 2.7
    COPs jumping ?
    happened to me once in a rainstorm, I had to stumble 200miles to home
  6. Mar 4, 2024 at 8:34 AM
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    I don't suppose you got some 85 octane up in the mountains did you? If so that can cause issues once you get back down low.
  7. Mar 5, 2024 at 3:19 AM
    Dberneski
    David
    Thanks for the response everyone. After driving it around more, it feels like it’s stuck in s6, in the manual mode. I was shifting through the mountains to increase speed going up. Just don’t know how it got stuck in s6, if that’s what happened
