Rough ride after 400 miles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by norcalguy, Mar 11, 2023.
  1. Mar 11, 2023 at 11:25 AM
    norcalguy
    norcalguy [OP] New Member
    Northern California
    2023 Off-road, long bed
    I recently bought a 2023 off-road, and for the first couple hundred miles it was such a smooth ride. I came from a 2002 4runner with 250k miles, so it was a huge improvement in the ride. At about 400 miles, I suddenly felt like the ride for much worse, especially on the highway. I feel like every bump shakes the car. This coincided with me having a bakflip mx4 tonneau cover being installed. Has anybody else had this experience? Is this some sort of break in period of the suspension or did the tonneau impact the ride?
    Edit: I bought the car new with 16 miles on it.
    Thanks,
  2. Mar 11, 2023 at 11:30 AM
    Bishop84
    Bishop84 Well-Known Member
    Start with tire pressures. Anywhere over 35psi has poor returns on ride quality with these trucks. 29-30psi cold is spec and is best.
    Also cold weather impacts shock performance, usually will ride a little more harsh.
    Chew likes this.
  3. Mar 11, 2023 at 11:30 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Check your tire air pressure. My sr5 with the factory tonneau cover rode rough till around 5k miles before it settled in. Tire pressure is crucial. A few psi too much, these trucks get bouncy.
    Chew likes this.
  4. Mar 11, 2023 at 12:24 PM
    norcalguy
    Northern California
    I appreciate the input. My tire pressure is 35 I believe. The dealer might have filled them up when they installed the cover. I will give it shot.
    Steves104x4 likes this.
  5. Mar 11, 2023 at 12:24 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Balance tires. Maybe a weight fell off?
  6. Mar 11, 2023 at 12:59 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    You added a bit of weight, OR has soft suspension/valving in shocks.
  7. Mar 11, 2023 at 1:03 PM
    Domeimazn
    Domeimazn Well-Known Member
    Henro
    2020 tacoma pro
    Def check the tire pressur3
  8. Mar 11, 2023 at 1:03 PM
    TacoDinner
    TacoDinner Well-Known Member
    I also installed a Bakflip MX4 cover on my Tacoma and haven't noticed any change in ride quality. Probably something else is causing it.
  9. Mar 11, 2023 at 1:05 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    That cover is what, 50-75 lbs. That's like having a small kid in the truck with you. Not going to change the way it rides.
    Chew likes this.
  10. Mar 11, 2023 at 1:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe put some weight in the bed
  11. Mar 11, 2023 at 1:09 PM
    na8rboy
    WI
    Everyone feels things differently. His rough ride, maybe someone else's smooth ride.
  12. Mar 11, 2023 at 1:25 PM
    islandhiker
    islandhiker Well-Known Member
    Calgary, AB
    2021 TRD Off Road AC
    35 is on the upper end I think (please double check though!) I usually keep mine at a cold 29/30 and that works well for me. If its a real pain, I'd just take it back to the dealer & see what they say.
    Chew likes this.
  13. Mar 11, 2023 at 1:36 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it will ride rougher when the weather is warmer because the tire pressure goes up
    Chew likes this.
