Rough ride after Bilstein upgrade
Discussion in 'Suspension' started by BoyzMom, May 6, 2018.
  1. May 6, 2018 at 10:22 AM
    BoyzMom
    BoyzMom [OP] New Member
    Linda
    2010 X-cab Tacoma
    Bilstein 5100
    Hello everyone, new to the site and looking for some help. I have a 2010 Tacoma 4x4 extended cab with 48,000 miles. This is my baby and I recently upgraded to a Bilstein 5100 shock/strut and was to have a 2.5 lift, but it ended up being only 1.75? Prior my truck was solid on the road and now at 50mph it shakes bad. I pulled a trailer that I have pulled many times barely knowing it was there, and now the truck rode so rough I thought I was in a Ford! Has anyone else had this issue with this shock system. My truck is not off road, just wanted a little more height. Appreciate your time.
  2. May 6, 2018 at 10:27 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Welcome to TW!! :cheers: hope someone has the info you need :)
    oscolivar1 and BoyzMom[OP] like this.
  3. May 6, 2018 at 10:30 AM
    tcjacado
    tcjacado Well-Known Member
    You compressed the spring to get that lift? Did you get an alignment after the lift? What did you put in the rear to get the lift?
  4. May 6, 2018 at 10:38 AM
    BoyzMom
    Linda
    2010 X-cab Tacoma
    Bilstein 5100
    There was an alignment, actually 2 as the first one pulled to the left and had to be re-done. I had the work done by 4 Wheel Parts, so I do not have the details on install specs. I was told that one side was slightly off to the other? The lift was the bring the front up primarily. I was also told the tires were feathered. Tires are BF Goodrich All-Terrains with less than 20,000 and no problem prior.
  5. May 6, 2018 at 10:44 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    5100 Bilsteins are "stiffer" than any factory shock offered by Yota. I've towed up to 7K lbs with my Taco, after I installed the 5100's, and the ride was just fine. I too have B.F. All terrain tires. And no, I don't have any of the problems you describe. The 5100's have been on my truck for over 6 years, and 75K miles.
    RogueTRD likes this.
  6. May 6, 2018 at 10:45 AM
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    I'd first check tire balance. Perhaps a weight got knocked off.
  7. May 6, 2018 at 10:48 AM
    tcjacado
    Is the vibration there only when towing?
  8. May 6, 2018 at 5:03 PM
    Dhannah
    Dhannah 2017 Tacoma OR DCSB
    Daniel
    North Carolina
    '17 DCSB OR TRD 4x4
    Under Construction
    Do you have the coils compressed to much?
  9. May 6, 2018 at 6:39 PM
    oscolivar1
    oscolivar1 Well-Known Member
    Oliver
    VA
    2017 Tacoma Limited
    Bilstein 8112/8100, JBA UCAs, Icon RXT leaf pack, work wheels 17x8.5;-10os, 285/75/17 cooper LTX AT3, Mobtown HC rear bumper and Sliders, SSO front bumper, BAMF greceased grill.
    You need to ask them for the papers for the work done on your truck...not knowing what was done is not exactly a good idea, especially if your saying if this is your "baby" :boink:
    Did they just install 5100 all the way around and at what clip/perch setting is it set at?, did use aftermarket springs like OME 887 or did you use the stock springs, how was the rear end lifted...aal, 3 leaf aal, blocks, full leaf pack. Or did you leave that stock cuz you said you just wanted to "primarily" lift the front, what tire size are you running?
    **What was your alignment numbers off the alignment sheet which is the most important if they had to do it twice... Upper control maybe needed...
    5100s are proven as a good set...as many run them in different variations.
    You want help we need details...
    Dhannah likes this.
  10. May 10, 2018 at 9:03 PM
    FishingInSand
    FishingInSand Well-Known Member
    Corey
    Temecula
    06 now with 4x4
    Some stuff here and there
    It's 4 wheel parts... I'm more certified then their techs lol
