Rough ride after installing 3” adjustable Bilstein lift on 2007 TRD tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacotruck07, Jan 17, 2020.
  1. Jan 17, 2020 at 9:45 AM
    Tacotruck07
    Tacotruck07 [OP] Member
    Graydon
    2007 TRD Tacoma
    3” toytec coil springs Bilstein 5100 adjustable shocks Fuel Vectors 17x9 Nitto Ridge Grapplers 285/70/r17
    Hey guys, new to the forum. I need some opinions on a lift issue. I installed the 3” adjustable Bilstein lift with toytec springs and the AAL in the rear.
    Toyota aligned it, but it’s still a pretty rough ride from about 20mph-60mph. Maybe they didn’t align it to lifted specs? Also the truck has developed a vibration at pretty much all speeds. Needle pin maybe?
    Let me know what you guys think, thanks!!
    Has 285/70/r17 nitto ridge grapplers if that helps any.
  2. Jan 17, 2020 at 9:47 AM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    What's the air pressure in the tires? The AAL is also from Toytec?
  3. Jan 17, 2020 at 9:49 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    5100S don't ride that nice to begin with. but you could lower your tire pressure to compensate
    whatstcp likes this.
  4. Jan 17, 2020 at 9:51 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    My bilsteins with toytec 600lbs springs set at zero ride fine.
  5. Jan 17, 2020 at 10:36 AM
    Tacotruck07
    Graydon
    2007 TRD Tacoma
    @replica9000 yes they’re the 2” toytec AAL. Tires are right at about 40 psi.
  6. Jan 17, 2020 at 10:42 AM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    You probably need UCA’s to get the caster correct.
    zippo88 likes this.
  7. Jan 17, 2020 at 10:48 AM
    Tacotruck07
    Graydon
    2007 TRD Tacoma
  8. Jan 17, 2020 at 10:51 AM
    QuicksandTaco
    Cody
    Oregon
    Total chaos, icon, camburg, dirt logic are a few off the top of my head. I don’t know models just search for your Tacoma year.
  9. Jan 17, 2020 at 10:53 AM
    zippo88
    zippo88 Well-Known Member
    L
    2012 sport
    Does caster effect compression characteristics ( softness stiffness of shocks?) .. thought it just made steering feedback more pronounced?
    t.hornstra and whatstcp like this.
  10. Jan 17, 2020 at 10:57 AM
    QuicksandTaco
    Cody
    Oregon
    It could cause alignment to not be in spec which would cause a bad ride. It’s hard to say what op considers a rough ride compared to anyone else though. For all we know it could ride fine and he’s just not used to a lifted truck with mud terrains.
  11. Jan 17, 2020 at 10:59 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    40 psi in the tires would do it. Try lowering that to 35 and see how you like it.
  12. Jan 17, 2020 at 11:01 AM
    Tacotruck07
    Graydon
    2007 TRD Tacoma
    @QuicksandTaco you are probably right. I’ve never owned a lifted Tacoma so I’m new to the feel. But I do know that the vibration that is happening isn’t normal. I’ve read the threads about the ECGS bushing and some of the issues it can fix and it seems to explain what I’m feeling (the vibrations at least). Simply just trying to get some different opinions before I go tearing into anything.
  13. Jan 17, 2020 at 11:06 AM
    Tacotruck07
    Graydon
    2007 TRD Tacoma
    @DriverSound i will try that out and see what happens, thanks!
    DriverSound likes this.
  14. Jan 17, 2020 at 11:07 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    I’d drop the air pressure to 35psi..
    What load range are your Nittos? they do make them in a 12 ply/load range F. Which would probably suck on a Tacoma.
    Might consider checking driveline angles. Changing them can cause driveline vibrations.
  15. Jan 17, 2020 at 11:08 AM
    QuicksandTaco
    Cody
    Oregon
    Try the bushing. Did you have axle shims installed? A lot of people have luck adding 2 degree shims under the leaf pack to adjust drive line angles.
  16. Jan 17, 2020 at 11:15 AM
    QuicksandTaco
    Cody
    Oregon
    Just because you over hear your girlfriends friends saying that to her, doesn’t mean it’s sound advice for other people.:cheers:
    Tacotruck07[OP] likes this.
  17. Jan 17, 2020 at 11:53 AM
    Tacotruck07
    Graydon
    2007 TRD Tacoma
    @Greenedmc i dropped it, about to take a drive and see. And I didn’t get the 12 ply tires lol, didn’t see any reason for that. I’m looking into the driveline angles right now.
    @QuicksandTaco i didn’t do the shims, but I did just look at the OME shim kit and it looks promising, and cheap. I’m going to try that out and see what happens. Thanks for the input
  18. Jan 17, 2020 at 11:58 AM
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Let us know if lower tire pressure works.
    I ran my Ridge Grapplers at 34 psi. Made a big difference in the roughness of ride.
  19. Jan 17, 2020 at 12:22 PM
    Tacotruck07
    Graydon
    2007 TRD Tacoma
    Lowering the tire pressure definitely improved the ride. I think I would still benefit from UCA’s just to get a more specific alignment. Ordering the shims now to see if that helps with the vibration. I will update this thread once I get them under the truck. Thanks again y’all for the input
  20. Jan 17, 2020 at 5:01 PM
    Greenedmc
    Daniel
    Elizabethton TN
    Just btw. The shims you need will be based on what your drive line angles are and how many degrees are needed to correct it. There are multiple options.
