rough ride on highway?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by livesinthesea, Jun 21, 2009.
  1. Jun 21, 2009 at 9:49 PM
    livesinthesea
    livesinthesea [OP] Member
    I just drove home 4 hours on the highway in my new used 2007 tacoma. It's a prerunner long bed double cab with trd sport.
    When the highway was new and super smooth the ride was fine, but on stretches where the highway had older pavement the ride sucked. The truck shook so much I pulled over to check that I wasn't getting a flat. No flat, tires looked fine. Any ideas what to check for?
    It has road tires, and the treads are a little low so they need replacing soon. They were just checked out and inflated to correct pressures at the previous owner's toyota dealer the day I bought the car.
    It has 40,000 miles and it has platinum warranty, so I'm guessing I should be able to get whatever it is fixed for free at the dealership.
  2. Jun 21, 2009 at 9:52 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    Could it be the older pavement? :eek:
  3. Jun 21, 2009 at 9:55 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    California Roads SUCK!! I would say its the road if it rides fine every where else. My truck is a lot louder and rougher riding in Cali then here in Oregon.
  4. Jun 21, 2009 at 9:56 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    our trucks arent known for the excellent ride quality, so it might not be a problem
  5. Jun 21, 2009 at 10:21 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    That would bug me too. Hopefully it's something minor. Sometimes a wheel can throw a weight & cause the truck to pick up a vibration. Also, gradually the alignment can get outta-whak over time. I would try taking it into a tire shop and have them inspect first. Are all of the tires wearing evenly? The driveshaft is also a "balanced" component although, less likely to become imbalanced than the tires. Don't want to jump to conclusions here. I've always had success with trying to keep things simple. Hope these ideas steer you in the right direction. It can be irratating when your vehicle isn't riding smooth. :confused:
  6. Jun 21, 2009 at 10:52 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i drive country roads daily cause my truck is also a work truck
    the tacomas drive like a true truck, they dont ride as well as other vehicles and some other midsize trucks (ahem ahem honda ridgeline) however their functunality and quality far exceeds these other vehicles
    you have to make a trade off somewhere and id rather ride a lil rougher and drive a taco than be in a nother vehicle and not even to be able to get outta the driveway because it breaks so much
  7. Jun 22, 2009 at 4:20 AM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...I vote for it's the road you were on. It's a truck not a caddy or anything...I'm not sure there is anything that the dealer can "fix" under your warranty....They don't do repaving....
  8. Jun 22, 2009 at 7:42 AM
    carmellocafe
    KEVIN
    N. California
    I see you are in the Chico, CA. area. I drive through there all of the time. In fact, I'll be driving through Chico to get to Yuba City today. What highway were you on when this happened? I'll take my Prerunner there & have a look-see for ya. To distinguish if it's the road. I usually take highway 99. I drive up & down "Skyway" a lot too.
  9. Jun 22, 2009 at 7:44 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    Im sure its the road/highway. It is a rough ride, bouncy and all.
  10. Jun 22, 2009 at 8:08 AM
    techgeekwill
    techgeekwill Well-Known Member
    Spring, TX
    18 Inferno TRD OR DCSB
    When you say they were inflated to proper pressure, did you actually verify this?
    Check the sticker in the side of the door frame on the drivers side. Most of the time, dealer monkey's don't bother to check the "actual" pressure recommendation, and just do it to whatever they want. Also, if you have larger tire's or aftermarket wheel's, the pressure may be different. If they are over-inflated, you'll get a rougher ride.
    Other than that, It's probably fine. I agree that California roads suck. The Camry that I drove from LA to Bakersfield when i was there felt like a Kia Rio on that highway. It's a truck, so the ride is going to be harsh no matter what you do.
  11. Jun 22, 2009 at 1:04 PM
    carmellocafe
    KEVIN
    N. California
    Tire air pressure does make a tremendous difference in the ride for sure. I think we're all thinking along the same line--Majority of rough ride issues have something to do with tires. If your on highways near the Bay Area, they are notorious for being messed up due to the extremely heavy traffic & lack of state funding to upgrade and maintain. IMO Sacramento is the worst. If you can, take it for a little test run on a known smooth stretch of road and then post back with what you find. (You've got me curious).
  12. Jun 22, 2009 at 1:06 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I have the same thing in my Tundra. Certain parts of the road are like pothole infested rumble strips and the newly paved asphalt is golden. I blame any organization with the three letters "DOT" involved.
  13. Jun 22, 2009 at 1:11 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Tire pressure is huge in ride quality. You also realize you bought a truck, right?
  14. Jun 22, 2009 at 1:19 PM
    BigJLarse83
    BigJLarse83 Well-Known Member
    Salt Lake City, UT
    06 DC PreRunner TRD Sport
    I have a Double Cab PreRunner Long Bed and when I drive on concrete highways the ride is pretty bouncey. Every other surface is just fine. It rides better with a little weight in the back. Went camping this weekend with all the gear in the back and it was much smoother on the concrete roads. My tires have less than 2k on them so I don't think it's an issue with those. I really can't complain though, I just came from an 03' Xterra that could make you jiggle in places you never thought possible.
    The few people I've talked to just tell me it's the nature of the beast and the leaf spring suspension. I've wondered if going to Billy 5100's would help any. The truck does have 72K on it and I have no idea if the shocks have ever been replaced.
  15. Jun 22, 2009 at 3:21 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    You're confused, you called the Skirtline a "truck".
  16. Jun 22, 2009 at 3:35 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Did you just trade in a Caddy on the Taco?
    If your ride continues to be that bad, maybe the shocks are bad?
  17. Jun 26, 2009 at 8:21 AM
    livesinthesea
    thanks for everyone's input
    my update is that I just took my taco in to Les Schwab to see if they could see anything obviously out of whack - and the balance was way off on the wheels. One of the front wheels was off by 1.5 ounces.
    I haven't had the chance to try it out yet on a big drive, but on the small drive I did so far it still seems to be vibrating. I read up about the Hunter road force balancing so may check that out and alignment too. Not sure whether to pay for all that now or just live with it for the moment and do it all in 2-3000 miles when I replace all my tires.
  18. Jun 26, 2009 at 8:49 AM
    carmellocafe
    KEVIN
    N. California
    Cool. Keep at it. Persistence usually pays off--JMO
