Rough ride
Discussion in '5 Lug' started by Logan89, Jan 11, 2011.
  1. Jan 11, 2011 at 2:13 PM
    Logan89
    Logan89 [OP] Member
    I have a 2009 acces cab with the readylift and 265/65/17 tires and the ride is very rough. I have rancho shocks in the rear and the stock shocks in the front. Is there anything I can do to make it ride a little smoother? Is everyone else's ride this rough with the lift?
  2. Jan 11, 2011 at 2:20 PM
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    I have the fat bobs garage lift in mine, it's esentially the same lift. I know everyone puts 5100's on their 4x4s, but they don't make them for the 2nd gen 5 lugs. My ride is not good as stock, but definetely not rough. I want a better lift too.
  3. Jan 11, 2011 at 2:43 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    maybe get aftermarket shocks for the front, i know bilstein actually makes some for our trucks
  4. Jan 11, 2011 at 3:16 PM
    95SLE
    95SLE Starting to get cold outside
    Tom
    Maryland
    09 RWD Access Cab
    Custom XM Install, Window Tint, Intermittant Wiper Install, AVS Bug Deflector, Bed Mat, TRS FX-R retrofits, CIBIE fog and spot lamps, PIAA 510 lamps, Acess LE cover, Weathertech Digital floorr mats, LED interior lighting, Pioneer AVH-2300BT HU, Boston Acoustics speakers, JL Audio Amp, shorty antenna, leather wrap steering wheel cover, Viper security system.
    I am researching shocks right now. I also read that Xrunner shocks will fit our 2nd gen Tacomas but there are not many options for X Runner shocks.
    Maybe we need to start a 5 lug suspension thread.
  5. Jan 11, 2011 at 3:20 PM
    113tac
    Stephen
    Northern Virginia
    yeah we could haha and maybe get it stickied..
    but yes the xrunner shocks fit our trucks, nesselerah has some front shocks that are for our truck, ill go look it up
    EDIT: here is the link from nesselerahs build. http://www.4wheelparts.com/Lift-Kit...iliate&utm_medium=Google&utm_campaign=Default
    here is a link to what is available from tirerack
    http://www.tirerack.com/suspension/...t+TPM&autoYear=2005&autoModClar=2wd&brand=all
  6. Jan 11, 2011 at 3:29 PM
    Johns Taco
    Albuquerque, NM
    A+++ to starting a lift thread for our trucks. It is just a complete mystery to me that they dont make a 5100 adjustable shock for the 5 lug. WTF
  7. Jan 11, 2011 at 3:31 PM
    113tac
    Stephen
    Northern Virginia
    yeah it sucks, but really, a lot of people that buy 5luggers dont plan on modding it, most of the time our trucks are bought for fleet vehicles or just because someone wants a truck but doesnt want to spend a lot on
    it seems like there are a lot of people that want to lift them on here but thats why we are here, because we want to do that stuff haha. now i dont know the geometry difference between our suspension and 6 lug suspension so i cant speak about the technical stuff
  8. Jan 11, 2011 at 3:40 PM
    Johns Taco
    Albuquerque, NM
    I definitely didn't plan on lifting when I bought my truck, 5 years later I lifted it and put 30s on it. Seems like lifting our trucks is real popular though, almost everday someone is posting a thread asking questions about this.
  9. Jan 11, 2011 at 3:42 PM
    Johns Taco
    Albuquerque, NM
    Hey 133tac, what part of va you in?
  10. Jan 11, 2011 at 3:52 PM
    113tac
    Stephen
    Northern Virginia
    yeah at first i was actually gonna go lower, but once i saw one lifted i changed my mind, but im in stafford
  11. Jan 11, 2011 at 6:28 PM
    Logan89
    Logan89 [OP] Member
    Yes it is very noticable. Bilstein does make HD shocks for the rear too, do you think those would be better even with the lift?
  12. Jan 11, 2011 at 8:40 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Just make sure you get the rear shocks made for a stock 6 lug. They will have the extra length you need to accommodate for the lift.
  13. Jan 11, 2011 at 9:45 PM
    Logan89
    Logan89 [OP] Member
    I was thinkng that too but wasn't sure if they would fit.
  14. Jan 12, 2011 at 5:15 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    THX for the info. I would tend to stay away from the KYB option because on one of the car forums I belong to KYB does make replacement shocks but most of the guys perfer Monroe. Seems the KYB shocks did not last all that long and the Monroe out performed them when cornering.
  15. Jan 12, 2011 at 6:11 AM
    afd23a
    The Dynamo of Dixie
    Yes they will fit just fine. If you run stock 5-lug shocks you won't have very much up travel in the rear and the ride will be rough.
    I'm running bilstien HD shocks all around with the fat bob's lift. Up front are the HD struts for the 5-lug, and in the rear are HD shocks for the 6 lug. The ride is a little stiffer than stock, but not bad at all. You could probably run the 5100's in the rear if you wanted, I'm not sure how well they would pair with the HD's up front.
  16. Jan 12, 2011 at 7:29 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Do you find with your set up that the Tacoma tracks with a more solid feel in the turns. That is with less roll of the Tacoma to the outside of the turn?
  17. Jan 12, 2011 at 8:18 PM
    afd23a
    The Dynamo of Dixie
    Yes I think it's better than stock. It still rolls slightly to the outside of the turn but it's better than without the lift IMO.
  18. Jan 13, 2011 at 10:16 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    XR runner shocks WILL fit but they are actually quite a bit stiffer than stock, and a tad bit shorter as well. And im not sure how they would do with the stock softer spring rate springs that come with the regular 5 lug
  19. Jan 14, 2011 at 2:14 AM
    95SLE
    Tom
    Maryland
    09 RWD Access Cab
    Kelsom:
    I was going to send you a PM about your set up. It looks like you have the Bilistein replacement shocks. Did they make your Tacoma track better thru turns and are you happy with them?
  20. Jan 14, 2011 at 2:44 PM
    113tac
    Stephen
    Northern Virginia
    yeah i thought i saw that on here somewhere, does that mean the rear XR shocks are shorter too?
