Rough ride
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Geekmercenary, Dec 17, 2018.
  1. Dec 17, 2018 at 7:42 AM
    Geekmercenary
    Geekmercenary [OP] Member
    Hello,
    I’m new to the group and just bought a 2019 off-road.
    For some reason, driving under 40mph feels a little rough, not quite vibration but slightly bouncy.
    I’ve had quite a few pickups over the years and don’t know if this is a characteristic of the Tacoma ride.
    Any thoughts?
    Thanks.
  2. Dec 17, 2018 at 7:48 AM
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    The OR suspension is referred to by some owners as a bit spongy, vs it's sport counterpart. You'll probably be appreciate it when you're off road, however.
  3. Dec 17, 2018 at 7:53 AM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    Welcome to the fit and comfort of a Tacoma... not the truck’s best asset. Also welcome to TW, lots of great info available to solve almost any issue you run across... and many many many great mods, ideas, experiences shared!
  4. Dec 17, 2018 at 7:55 AM
    Geekmercenary
    Thanks for the reply.
  5. Dec 17, 2018 at 8:07 AM
    McKBrew
    McKBrew Active Member
    Jess
    North Idaho
    2018 TRD OFFROAD DCSB Quicksand
    I feel that the Off-road can be a bit bouncy. When going to the dump one day with a loaded bed it seemed to be a bit smoother with weight in the back.
    I bought a few bags of sand and keep it in the bed at all times now.
  6. Dec 17, 2018 at 8:09 AM
    K9taco18
    K9taco18 Well-Known Member
    Luis
    2018 offroad
    Lift,RRW
    Sounds like a good excuse to sell aftermarket suspension to your significant other with adjustable shocks since you’re so thoughtful....
  7. Dec 17, 2018 at 3:28 PM
    daveometrod
    daveometrod Well-Known Member
    18 TRD OR 4x4 DCSB Blazing Blue
    New vehicle, you need to check the tire air pressure against the door pillar label.
    It seems almost universal that Toyota dealers think you are leaving the dealership with your truck carrying the maximum load.
    TacomaUSA likes this.
  8. Dec 17, 2018 at 3:34 PM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    I second that, I bet the air pressure is way high. 29 lbs cold. I say 30 cold and they might get to 33 lbs and your ride should smooth out
  9. Dec 17, 2018 at 3:36 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    should have gotten the Sport model
  10. Dec 18, 2018 at 8:10 AM
    Geekmercenary
    35lbs of pressure cold. Thanks for the input. Time to deflate the tires.
  11. Dec 18, 2018 at 8:12 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    "rough" and "bouncy" are kind of the opposites...
    Gunnar_19 and HelloMyNameIs like this.
  12. Dec 18, 2018 at 8:12 AM
    SlappyMcSlapnuts
    SlappyMcSlapnuts Well-Known Member
    Don
    2019 turd
    Curb feelers
    You think that's rough you should drive a Sport over some potholes.. those things will shake kidney stones loose.
  13. Dec 18, 2018 at 8:13 AM
    vuTron
    SF Bay Area
    Sport model has a stiffer ride compared to OR. Might be more "rough".
  14. Dec 19, 2018 at 11:20 AM
    Dr.ZZ
    Dr.ZZ Member
    Krammer
    2017 TRDOR DC
    Stock
    True that. Sport and Limited incredible harsh ride. Potholes are "jarring" to say the least. I traded a 2016 Limited for a 2017 TRD Off Road and I'm much happier with the on-road ride. Much.
  15. Dec 19, 2018 at 2:15 PM
    tallpilot
    tallpilot Well-Known Member
    David
    Florida
    2016 TRD OR 4X4 DC SB AT Silver
    Mobtown sliders, RCI skids, Bilstein 6112/5160/Dakar, DuroBumps
    Put some weight on it and once the springs settle a bit it will stop feeling floaty.
  16. Dec 19, 2018 at 2:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Just a note that the harshness in the Sport over uneven bumps and potholes is not shocks and springs but the sway bar.
  17. Dec 19, 2018 at 2:43 PM
    slamson00
    slamson00 Well-Known Member
    Northern California
    2019 Tacoma TRD Off Road DCLB
    My thought are my 2019 TDF OR DCLB rides amazing. I like the plushness of the OR suspension. Performs well off the pavement when I take it there. But I am used to truck suspensions as I have been driving them for almost 20 years. The OR has a little more body roll in curves then the Sport I hear, but that makes sense with what I have read from people experience with the Sport.
  18. Dec 20, 2018 at 5:58 PM
    Jh8473
    Jh8473 Well-Known Member
    Bowling Green
    2025 Tundra SR5
    None
    Said no one ever!
