rough ride
Discussion in 'Suspension' started by thisERICtaco, May 11, 2010.
  1. May 11, 2010 at 12:06 AM
    thisERICtaco
    thisERICtaco [OP] Well-Known Member
    Eric
    CA, oc
    06 AccessCab SR5
    so ever since i upgraded to the pro comp oil shocks going over speed bumps was heaven
    but going over like construction roads or bumpy roads it rides like shit as if the shocks were blown
    any ideas on what to do
    should i buy new shocks and trash the oil ones i have since i feel like i lost money anyway
    i keep thinking of a brand that would fit a 5 lugger but i dont think there are any and if i get nitro filled then wouldnt it lift me a lot and then look weird or drive weird
    any ideas would be super helpful thanks a lot
  2. May 11, 2010 at 12:08 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Just to confirm, you're a 5-lug, yes?
    And switching to nitrogen charged shocks shouldnt really lift the truck any, just so ya know.
  3. May 11, 2010 at 12:11 AM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    o ok cool no extra lift i wish my front was more lifted cause i put 32 tires instead of 31 and the well is small again =[
    but yeah i am a 5 lugger 2.7 taco no prerunner no anything else
  4. May 12, 2010 at 12:01 AM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    aww no answers =[
  5. May 13, 2010 at 4:57 AM
    ToeCutter66
    ToeCutter66 Active Member
    Kevin
    Sterling VA
    09 4x2 5-lug
    None, yet.
    I have procomps and the Ready Lift on my 09 base reg cab. And I must say it rides like ass. If I had known that making these changes would ruin my ride, I might not have done it. I think mine rides badly because of the rear aal, not the procomps.
  6. May 14, 2010 at 12:39 AM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    hell yeah man
    i hate this
    i want a nice ride
    i already know i fucked up with having 32 tires when i shoulda got 31 but my suspension should be better
    the rears suck so much
    i know the aal makes it ride rough over speed bumps but theres gotta be a shock to fix all this and it sucks even more how our leaf springs are under the axle and not over =[
    someone with shock experience please help i think nitro socks would be a lot better then the dumb oil ones
    whats the point since it doesnt pop back up
  7. May 14, 2010 at 6:02 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    i think pro comp shocks suck in general. i tell everyone. i have them on my truck and i cant wait till i get all of the parts to swap em out.
  8. May 14, 2010 at 11:46 PM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    yes pro comps suck
    what do you plan on getting?
    but youre so much different then us youre a prerunner
    do pre runner shocks fit in the rear of the 5 luggers?
  9. May 15, 2010 at 5:22 PM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    Am i suppose to get a longer shock since i have aal or am i just suppose to get a better shock like a bilstein which is the same length i believe??
  10. Jun 14, 2010 at 12:26 AM
    schiz94
    schiz94 Thread Jacker
    Caleb
    Bellingham,WA
    08 Tacoma Reg Cab
    Morimoto Projector Retrofit, alpine cda-105,Wheelskins leather wheel cover, wet okoles,5% tint on back and 24% on front two windows,Debadged tailgate,custom sockmonkey centercap decals, xr rims pced gloss black.
    post more pics. i wanna see it with those 32s and get a better pic. yours are all sideways haha
  11. Jun 14, 2010 at 1:19 AM
    Celtic
    Celtic Tactical Trunk Monkey
    Nick
    Willows, CA
    06 AC TRD 4X4 SR5 6spd
    BHLM, Devil horns, trimmed front flaps, Flowmaster muffler,
    A truck doesnt really ride "nice" speed bumps or rough roads. Dude its a truck. If your shocks were blown you would bounce all over the place because a shock is designed to to is to dampen your spring compression and extension to a manageable level, Example, you go over a speed bump, and it should bounce maybe 1 time after going over it. Without shocks it will bounce many times. Also over rough roads a truck without good shocks will be all over the road and bounce like nobodys business, Shocks can help a lot with that, but also with a AAL or even TSB springs, its going to ride more rough because of stiffer springs. So you have a mix between carrying weight (stiffer springs) and ride quality (softer springs that absorb every bump). A truck will lean more to the carrying weight and less to ride quality. Also the lower profile tires will also contribute to your ride quality, lower profile, (shorter the distance of rubber between the rim and the ground) the harsher the ride, Taller the tire, the more rubber between the rim and the ground the better the ride, but less responsive the handling. So its a delicate mix between the two, but unfortunately for you the Tacoma rides more towards the stiffer springs and carrying capability. Might check your air pressures, more psi the harder the tires will be, I wouldn't run anymore than 32-35 if you are worried about ride quality and dont haul much for weight. When I am towing or hauling a lot of weight, I typically run 40-45psi. Just my .02. Hope it might help shed some light on what you are experiencing.
  12. Jun 14, 2010 at 11:51 PM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    o i see
    but it doesnt ride as well as the other tacomas is what im saying
    i work at the dealership and i drive the lifted ones and the ride quality is so much better
    just wanted to make the truck ride as good as a v6 trucks is all and i will post more pictures when i get a camara
  13. Nov 21, 2010 at 2:58 PM
    jcmartinez17
    jcmartinez17 Well-Known Member
    jc
    ontario
    10 trd tacoma prerunner
    i got the same problem and i have a 2002 double cab with icon shocks in the front which are supposse to be one of the bests in the markets, and the ride is still not smooth, could it be that i have a I4? my cousins has a v6 with the same shocks and his ride is way better
  14. Nov 21, 2010 at 6:15 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2017 dcsb trd offroad blazing blue pearl
    problem is the model u have. not the shocks. the reason the lifted ones u drive ride better is cause u have a basemodel 2wd. your not gonna have as good a ride as a prerunner or a 4x4. but u also didnt pay as much for the truck either. thats the way it works brotha..
  15. Dec 15, 2010 at 12:41 AM
    thisERICtaco
    Eric
    CA, oc
    06 AccessCab SR5
    i know the 4 banger sucks. but i found a fix for the shocks.
    put tacoma prerunner bilsteins on and it works great. i got them from a previous lifted truck and they left it behind.
    and now the length of the prerunner shock in the rear helped with the problem. so basically get a longer gas shock.
