Rough Riding 96 tacoma 4x4, need recommendations for fix.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wingokidd, Sep 18, 2015.
  1. Sep 18, 2015 at 4:55 PM
    Wingokidd
    Wingokidd [OP] Member
    1996 Forest Green Extended Cab Tacoma 4x4
    Hello All,
    I've had my 96 tacoma 4x4 garaged for the past 10 years and now it's back to my daily driver. Driving it now daily, i'm realizing how rough the ride is. It's got 185K miles so pretty low for the years but i need to fix the ride in the worst way. Any suggestions would be greatly appreciated. I've contemplated putting a lift on it but don't really want to break the bank or increase tire size.
    Thanks for help.
    Wingokidd
  2. Sep 19, 2015 at 2:27 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    What have you been driving??
    Give yourself time to get used to it again after all it is a truck and most likely your driving around empty
  3. Sep 19, 2015 at 3:58 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    96 Toyota Taco. 4x4 was a buck board, especially if were the standard cab. The shorter the wheel base the worse the ride. Check each corner and see if the shocks all respond the same. Other then that, adding a couple hundred lbs of weight ( four bags of tube sand ) to the back can calm it down a little. That is the cheapest fix.
  4. Sep 19, 2015 at 4:22 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Being a 98 and pretty high milage it could probably use shocks. Check everything for movement, steering rack, tie rods, ball joints and make sure the alignment is in spec. Tires and pressure can play a part as well.
  5. Sep 19, 2015 at 4:29 AM
    Wingokidd
    I drove this truck as a daily work vehicle from 98-2005 and loaded it pretty heavy so the leaf springs were taxed to say the least, so i know those could stand to be replaced and i'm planning on replacing the front coil strut assembly as well. Don't get me wrong, I'm willing to invest some $$ to get it riding better, looking fore some recommendations on good proven parts and to hear what has worked for others. Thanks for replies.
  6. Sep 19, 2015 at 4:44 AM
    TACO TX
    Kelly
    Denison ,Texas
    You can get a set of Moog coils from Rockauto for about $50 and then a decent set of shocks. Wheelers progressive mini pack added to springs and take out overload in rear works good if you need some extra capacity.
    Wingokidd[OP] likes this.
  7. Sep 19, 2015 at 5:29 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Those coils, springs, bushings have been supporting weight for 20 years. Went through all the suspension on my 96 last year with a toytec lift and new leaf pack. Rides pretty damn good compared to what it did. Gona start going through the bushings with the poly ones.
  8. Sep 19, 2015 at 8:02 AM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    What is your tire size and air pressure? Big tires can make the ride horrible. Too much air can make the ride much worse.
  9. Sep 19, 2015 at 11:18 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    After sitting for 10 years ??
    At a minimum, I'd take the eyebolts out of the rear leaf springs and the bolts / shackles off / out. Inspect & clean the bushings and grease the shit out of everything. or ....buy new bushings & hardware. Check your rear shocks too...make sure they're not 'frozen' in place.
  10. Sep 19, 2015 at 11:27 AM
    SlipperyTaco
    SlipperyTaco Slippery when Wet
    Chandler, AZ
    04 Tacoma 4x4 & 2014 4Runner Trail Premium
    FOX 2.5 C/O, CAMBURG UCA, FOX 2.0 REAR, SMP CUSTOM FRONT BUMPER, BAMF LCA SKIDS, SCS RAY 10 MATTE GREY WHEELS, 305/70/16 BFG KO2, ALL PRO STANDARD LEAF PACK, ALL PRO SLIDERS, U-BOLT FLIP KIT, MARLIN CRAWLER REAR BUMPER, TIMBREN REAR BUMPSTOPS, WHEELERS SS BRAKE LINE F/R, D-BADGED, GIBSON CAT BACK, K&N CAI, LINE-X , GREY WIRE MOD, APOLLO 3.0 SHROUDS, D2S XB 5500K HID BULBS, LED HALOS, LED DEMON EYES, TRS LED BULBS, BHLM, IGGY PODS, CALI RAISED PODS, 30" CALI RAISED 4D LIGHT BAR, BESTOP SUPERTOP, TRASHAROO , WET OKOLE SEAT COVERS. 4 RUNNER- 2014 TRAIL PREMIUM W/KDSS KINGS FRONT AND REAR DIRT KING BALL JOINT UCA METAL TECH LONG TRAVEL SPRINGS METAL TECH UPPER/LOWER LINKS SONORAN STEEL KDSS TRACK BAR URD EXHAUST URD Y PIPE URD MAF CALIBRATOR PEDAL COMMANDER PRINSU ROOF RACK RIGID ADAPT LIGHT BAR SCS SR8 17" GUNMETAL 285/70/17 FALKEN WILDPEAKS TRS FOG LIGHTS TRS HID KIT SS OFFROAD SLIMLINE WITH SIDE PROTECTION COASTAL REAR SWINGOUT HEFTY FAB SKIDS
    Great suggestions above from everyone, You just need to pick and choose what you want from here, I would suggest air down your tires for now it will help and go a few pounds less in the rear then the front. But if you get 5100's all around and any leaf pack it will be a huge difference for you in ride quality and comfort.
  11. Sep 19, 2015 at 11:32 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
