Rough shifting?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TriniPhantom, Nov 28, 2018.
  1. Nov 28, 2018 at 5:13 PM
    TriniPhantom
    TriniPhantom [OP] Well-Known Member
    Bay Area, California
    2018 Tacoma TRD Off Road DCSB
    Prinsu roof rack, Budbuilt Sliders, Avid Bumper Guard, MESO Ultimate Turn Signals, Door sill decals, Raptor Lights, Tailgate inserts, Mudflaps, Tri-fold Tonneau, DC Motorsports Muffler Tip, TVD Vinyl Decals, Many Interior Mods.
    In my 3rd Gen (just over 1600 miles), manual transmission, I find that shifting from 1st to 2nd to 3rd feels kinda rough, unless I'm revving high. Is that the triple synchros? Also when shifting from 5th to 6th I feel a small blip/kick when I release the clutch unless I roll off the clutch. This happens to anyone else?
  2. Nov 28, 2018 at 5:20 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Every clutch is different every vehicle is different. I just push mine in and let it out and it works. I don't expect a lot because it is a truck, not a Ferrari.
  3. Nov 28, 2018 at 5:20 PM
    e6400ultra
    e6400ultra Well-Known Member
    NorCal
    2017 SR AC 4x4 MT 2.7L
    My 2017 5spd MT has been the same way since day one. I find that stepping on the clutch pedal as firmly as possible helps, which makes me wonder if the master cylinder in these trucks tend to trap air, so bleeding the system isn't getting all the air out.
    TriniPhantom[OP] likes this.
  4. Nov 28, 2018 at 5:20 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
  5. Nov 28, 2018 at 5:23 PM
    DTaco18
    There are a bunch of other threads on this subject too.
  6. Nov 28, 2018 at 5:23 PM
    TriniPhantom
    I like that you call it crunchy. That really is the best description of it.
  7. Nov 28, 2018 at 5:24 PM
    TriniPhantom
    So you experience the same crunchiness when shifting as well then?
  8. Nov 28, 2018 at 5:25 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    It was more prevalent for the first 10K miles and now that I am close to 30K It is fine.
  9. Nov 28, 2018 at 5:26 PM
    e6400ultra
    NorCal
    The 5spd is exactly the same as your description of the 6spd, after 3rd it's smooth.
  10. Nov 28, 2018 at 5:29 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Rough like the shifter action is notchy, or does it feel like the syncros aren't quite up to the job on certain gears?
    My 5-spd manual's very notchy, always has been, even at 46k miles. It reminds me of my suzuki samurai haha.
  11. Nov 28, 2018 at 5:32 PM
    TriniPhantom
    Rough like shift action is notchy. Gears engage fine.
    su.b.rat and Paul631[QUOTED] like this.
  12. Nov 28, 2018 at 5:35 PM
    DTaco18
    I would say mine feels like the blocking ring is allowing the shift slightly before the gear speeds are fully sync'd, both with soft/slow and hard/fast shift. I've never had a true grind that could be heard, only crunchy feeling in the stick like the gear teeth aren't meshing properly. (still less that 5k miles)
  13. Nov 28, 2018 at 5:38 PM
    Sum1 Else
    Sum1 Else Well-Known Member
    Pop the clutch (5000 rpm) and stand in it.
    You guys are babying your rides too much.
    TriniPhantom[OP] and su.b.rat like this.
  14. Nov 28, 2018 at 5:40 PM
    DTaco18
    @TriniPhantom Try shifting 1-2 quickly after clutching (get from 1-2 before the rpm's drop 300rpm). That was recommended in a prior thread, and it does seem to smooth it out a bit; just don't miss the shift!.
    As fyi, I mentioned it during my first service to make sure it was documented (they just noted- No TSB available) and I plan to live with it until closer to the 5/60 warranty. If it's still an issue, I'll deal with it then.
  15. Nov 28, 2018 at 5:43 PM
    e6400ultra
    NorCal
  16. Nov 28, 2018 at 5:43 PM
    TriniPhantom
    Yea it just really feels like the synchros are syncing up.
    I would agree that the higher the rpm the smoother the shift.
  17. Nov 28, 2018 at 5:44 PM
    su.b.rat
    su.b.rat broken truck
    3 things in my mind.
    1 - you're new to the truck and your aim is not yet good enough. for sure. dial in your aim going into 2nd & 3rd with accuracy.
    2 - some recommend a trans oil change with something like MT90 and many report it helps, me included. actually the bit that helps there is likely that most find their boxes are under-filled which can of course create that symptom. i was a bit more than 1/4 qt low from the factory.
    3 - you probably will continue to break in and smooth out continually from here. and a short shift kit can help once you check your oil.
