Rough Start after Sitting for A Week
Discussion in '1st Gen. Tacomas (1995-2004)' started by kigmob, Apr 8, 2017.
  1. Apr 16, 2017 at 6:00 PM
    kigmob
    kigmob [OP] Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Does changing the boots require buying new coil packs?
  2. Apr 16, 2017 at 6:04 PM
    kigmob
    James
    New Orleans
    Cranks fine. Just idles rough for ~10 seconds and then is fine.
  3. Apr 16, 2017 at 6:41 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    no, and they're cheap. I don't understand why they don't come with NGK wire packs.
    They wear out just like a regular wire.
    The popping is what makes them suspect to me.
  4. Apr 17, 2017 at 7:20 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    Could be. It would run poorly until any coolant leaked into the cylinder burns off. How's your coolant level?
  5. Aug 8, 2017 at 12:23 PM
    kigmob
    James
    New Orleans
    Happened again when I got back from vacation. Had a bit of a knocking sound for a couple seconds. Really hope this isn't the beginning of a bigger issue. Any additional ideas guys?
  6. Aug 8, 2017 at 12:36 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    you've checked the injectors and replaced the boots?
  7. Aug 8, 2017 at 12:38 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I don't want to spread rumors but in I4 I had similar strange issue. Started in the morning idling rough like on 3 cylinders for maybe 5 - 10 seconds and then everything went away. Actually fuel consumption went down (I was doing 24mpg), but smog numbers were bad, very bad on NOx.
    Cutting long story short I ended up with water leaking into cylinder via busted head gasket. Water in the cylinder made it not fire up for few seconds till all water was expelled. ECM compensating for "wet" cylinder was giving less fuel and that made my mpg and NOx numbers. After head gasket job smog numbers went to "like new", but the mpg wend down too to my normal 20mpg.
