Rough start knocking after sitting
Discussion in '1st Gen. Tacomas (1995-2004)' started by austinsdad99, Sep 18, 2019.
  1. Sep 18, 2019 at 9:22 AM
    austinsdad99
    austinsdad99 [OP] Well-Known Member
    1999 prerunner 3.4
    Had a weird occurrence been outta town so my truck has sat about 10 days. Went to start it and it usually takes it a couple of spins (about 3 seconds) when cold to fire. It fired right up after a second the rpms jumped to maybe a grand and it stumbled and a very loud knock came from the driver side. I smelled smoke like burning oil for a minute then it all was normal.
    It doesn’t ever smoke or use oil at all. Has pennzoil full synthetic in it. The knock is what really scared me. I know these trucks tick but this was all out say 3 second knock like no oil was in the drive train. Level is full.
  2. Sep 18, 2019 at 10:56 AM
    ToyotaHunter
    ToyotaHunter Well-Known Member
    2003 Toyota Tacoma TRD
    is it still knocking when start it it after ?
  3. Sep 18, 2019 at 12:37 PM
    austinsdad99
    1999 prerunner 3.4
    No it stopped after a few seconds then slowly got quieter.
  4. Sep 18, 2019 at 12:54 PM
    ToyotaHunter
    i shouldn't see nothing to worry about if it isnt knocking. .mostly like because the truck wasnt started up in over a week it was a bit dry inside soon as the oil circulated reached those dry areas it lubbed them up.. happens alot up here in the north east i have 5 to 10 truck parked at my yard at a time for weeks when i starts them they do the same.
  5. Sep 18, 2019 at 1:01 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    I had the same thing happen on my 1992 XtraCab, after it had sat undriven for 2 weeks. Turns out I had water in the gas tank, and it got sucked into the pump & filter all at once.
    A buddy and I siphoned out almost 2 cups of water, from the 14 gallon tank, that was only ~half full of gas.
    After that, I never had a problem leaving it sit for weeks at a time--but I also made sure to keep the gas tank at least 3/4 full.
    You should be ok, but keep an ear on it.
  6. Sep 18, 2019 at 1:49 PM
    austinsdad99
    1999 prerunner 3.4
    I’m blaming it on the sitting. It’s usually driven daily. After swapping to the synthetic oil I’ve noticed the tick a little more when it’s first started.
  7. Sep 18, 2019 at 1:57 PM
    eon_blue
    Azusa, CA
    Hopefully it wasn't the oil pump struggling...hard to say for sure based on the description. Keep an eye on it and see if it repeats
