Rough turn off
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NW_Taco, Dec 14, 2016.
  1. Dec 14, 2016 at 9:56 PM
    NW_Taco
    NW_Taco [OP] Well-Known Member
    Super White Tacoma
    Hello everyone. I have a 2013 tacoma 4x4 and it's been turning off pretty rough. It seems to shake when I turn the key to off. It runs fine and idles fine. No probelms there, only when turned off. Can it be cause of the cold weather even though the truck is at normal operating temperature when turned off?
    Thanks!
  2. Dec 15, 2016 at 5:55 PM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    I thought all of our trucks did that...:eek:
  3. Dec 15, 2016 at 6:47 PM
    NW_Taco
    Super White Tacoma
    Well if they all do that, at least I'm not alone lol
  4. Dec 15, 2016 at 8:26 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Describe what you mean by rough.... like shakes, jolts, jiggles, sputters , etc?
  5. Dec 15, 2016 at 11:17 PM
    NW_Taco
    Super White Tacoma
    The whole front end of the truck just seems to shake.
  6. Dec 16, 2016 at 1:22 AM
    Caltech90
    Caltech90 Well-Known Member
    '19 TRD OR T4R
    MT or auto?
  7. Dec 16, 2016 at 5:36 AM
    TRDMountaineer
    TRDMountaineer Well-Known Member
    Ripley, WV
    2015 AC TRD Sport MGM 6-spd S/C
    TRD S/C, aFe Stage-2 Intake, Magnaflow 15315, Leer 100XQ w/ Tracker II Rack, General AT2 265/70R17, OEM skid, TRD FJ caps, Wet Okole Realtree seat covers, TRD grey shift knob, Weathertech floorliners, Weathertech window visors, Salex glove box+console organizers, Grid-It console lid mod, Lamin-X amber fogs, Craven Speed A-pillar phone mount, Debadged
    Is this your first truck OP?
  8. Dec 16, 2016 at 5:56 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Sometimes it's rougher than others. It's a lot of moving parts and energy to all of the sudden stop.
  9. Dec 16, 2016 at 7:49 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    My 2014 4.0/6MT is like that. I suspect soft motor mount material - nothing torn or broken on any mounts (that I could find, at least). It seems Toyota built an awful lot of slop into the drivetrain on these trucks to cut down on NVH (noise/vibration/harshness). My 2012 4.0/5AT didn't do it as bad, but I suspect the AT was just dampening the effect.
    My 1992 2.4L 22RE/5SP was similar, though. It was worse when the engine wasn't full up to operating temperature, but any engine shutoff would give a pretty good shake/wobble. FWIW, I drove that truck until the wheels fell off, so it didn't seem to hurt anything. :)
  10. Dec 16, 2016 at 9:38 AM
    NW_Taco
    Super White Tacoma
    AT and yes its my first Tacoma.
  11. Dec 16, 2016 at 10:06 AM
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    My 05 AT with 180k miles turn off very smooth.
  12. Apr 21, 2017 at 8:28 PM
    ButtaYoBreadd
    ButtaYoBreadd Well-Known Member
    2014 TRD OR DCSB
    Can anyone else comment on if their truck has a rough turn off like the OP? I test drove a 2013 DCSB trd with 40k that I noticed did this and I just want to make sure it's nothing to be concerned about. Thanks!
  13. Apr 22, 2017 at 6:16 AM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    IDK. It kinda sounds like "Dieseling" ? When you shut off the ignition the cylinder/plug may have a hot spot just hot enough to continue to fire remaining air/fuel mix that is in the intake system. Years ago before Computer this pointed towards timing too advanced or poor / cheap gas. Also sometimes after a long hard high speed run.
    I'd try this.
    - try a full new tank of better gas.
    - Ensure that the cooling system is really OK with no blockage/air bubbles/full/plugged radiator/ not leaking/low fluid etc.
    - Get a scan gauge and check for codes.
    - let the engine run for 30 sec or so before shutting off.
    - Start the engine cold - let it idle for a minute then shut off - does it still do it?
    - Start the engine cold - take it for a short run (5/10 Mins?) then shut it off and see if it still does the same.
  14. Jun 12, 2019 at 1:36 PM
    Janker
    Janker New Member
    Kyle
    Victoria
    Tacoma 4x4
    So my 2013 is doing this now all of a sudden @ about 90k on the engine. No codes, runs and idles fine, AC is working, only run 93 octane gas. Sounds like metal grinding or something similar when turning engine off.
    My first thought was my AC compressor or fan clutch might be going out? Likely?
  15. Jun 12, 2019 at 1:56 PM
    Canufixit
    New England
    Check my previous post above yours.... check and advise. Also check the motor mounts (open the hood, set the P brake put it in forward and give it a LITTLE gas then repeat in reverse. does engine lift / tilt to one side??
  16. Jun 12, 2019 at 7:43 PM
    4WD FTW
    4WD FTW Well-Known Member
    '08 DC LB 4x4
    Icon Suspension Kit Pelfrey Bumper and Skid 4.56 Gears Detroit TruTrac Rear Archive Hammer Hangers Deaver U402 Stage 1
    Mine has done this for as long as I can remember. It didn't bother me really because I've driven hundreds of old diesels that do it too. Seems to only do it after long drives not from idle
  17. Jun 13, 2019 at 6:51 AM
    obscurotron
    N. Nevada
    '14 DCSB 4x4
    I'll add to that list. My '14 will sometimes do a 'rough' shut off as well. Most of the time it happens if it's cold out, I start the truck to move it, then shut it right off (engine is running for < 2 minutes).
    But, I've also come back from 4 hour road trips, pulled into the garage, shut it down, and had that 'rough' shutdown, like a motor mount or trans mount is going bad.
    It reminds me of a motor running with a dead cylinder. The balance of an engine is based in part on the combustion of fuel - that explosion in the cylinder acting to push the cylinder down is a calculated and expected force that helps to balance (or counter-balance) the rotating masses inside the motor. I figure if you turn the key off at just the right time (whatever the odds are, multiply them by, what, 6?), you can have an unbalanced force (crank is pulling the piston down when that piston should have been 'forced' down) in the motor for a second.
    Other than rattling your teeth out, I can't really figure it will do much harm.
  18. Jun 13, 2019 at 8:58 AM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    That's what I was thinking. On the older carbureted trucks we used to shut them off in N instead of P and I think it helped.
  19. Jun 13, 2019 at 9:25 AM
    NYCTaco52
    NYCTaco52 Half man, half goat
    Somehow known as Stewart, but named Ben
    Ft Lauderdale, FL
    2022 Subaru Ascent
    Sounds like motor mounts are bad
  20. Jun 13, 2019 at 9:26 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    like a little shake or like a death shake that old diesels do when you shut them off lol
