Round 10 - HID Projector Retrofit Group Buy
Discussion in 'Group Buys' started by CayucosTacoma, Sep 21, 2012.
Thread Status:
Not open for further replies.
  1. Oct 12, 2012 at 5:42 AM
    #441
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    '13 MGM DCSB 4x4 TRD sport, Tow and Entune
    Tonnopro tonneau cover, Weathertech digital fit mats, Magnaflow 18" muffler with black exhaust tip, blacked out badges/emblems, Passport 9500ix, Pop & Lock PL8521, EZdown tailgate mod, 17" KMC XD addicts, 265/70/17 Nitto Terra Grapplers, OME 884 springs, Bilstein 5100's at zero, BHLM, FX-R retrofit, 80mm and 110mm morimoto rgb halo's with Bluetooth control, Raptor style led's in grill, LED's for dome, maps, reverse, license plate, parking lights, switchback DTRL's, ultra-gauge, Kenwood DNX690HD, Hertz HDP4, Hertz HSK165's, Memphis 12" in custom box, Black/Grey Roadwire leather kit with seat heaters, cool white interior led's from oznium.com, 20" AVEC dual row light bar in lower bumper, 19" AVEC single row light bar in grill,
    Well got mine pulled apart last night and got the bezels painted. Think I am going to leave the bowls alone. Also got the harness and both ballasts mounted and wired up, ready to just plug into the lights. Did a quick mock up of the projector with the alignment ring and they look to be off quite a bit clockwise. Just judging by holding the light as level as I can and looking through the projector to see the cutoff shield not level, tilted to the right. Is this what most have found? Have to modify the alignment ring a bit?
  2. Oct 12, 2012 at 9:23 AM
    #442
    ambiguous
    ambiguous Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    On the 2012-2013 this seems to be a common issue with the alignment ring on the Minis. See link below for solution done on a Highlander. There on other threads on TW as well.
    http://www.toyotanation.com/forum/1...light-retrofit-how-pic-heavy.html#post3614655
  3. Oct 12, 2012 at 9:33 AM
    #443
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    Thank you sir!
    One more question: I am planning on wiring the halo's to come on with the dtrl's. On the '13 there are 3 wires. Does anyone happen to know which 2 wires I will need to use?
  4. Oct 12, 2012 at 12:50 PM
    #444
    Tinyredtaco
    Tinyredtaco Well-Known Member
    Brandon
    AZ
    02 DCPreRunner TRD V6
    Bilstien 5100 front/back... Morimoto Projector retrofit.
    Ya they came in a little Baggie with the locking ring for the projector and rubber grommet and stuff, and they don't line up that well but once you start screwing them into place it pulls it together in the right place, just remember that the two holes on the bottom are farther apart than the two on the top. So make sure when you screw the shroud on there properly matched up or it will crack the plastic. Good luck
  5. Oct 12, 2012 at 12:52 PM
    #445
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Thanks! I didn't open that little baggie, I was just messing with the parts while sitting on my couch :eek:
    Just trying to make sure I have all my shit together before I head into the install. Nothing worse than getting everything torn apart and realizing you're missing a tiny, cheap, yet critical, part.
  6. Oct 12, 2012 at 2:05 PM
    #446
    Rascal737
    Rascal737 Well-Known Member
    Oliver
    Abbotsford, BC
    09 Silver DCLB TRD Sport 4X4
    Python 574 Remote start/Security system, reusable cabin air filter, led map and dome lights, led bed lights, switchback dtrl's, aftermarket dual halo projector headlights retrofitted with TRS goodies, foglights on anytime, Illuminated 4X4 switch, Redline hood struts and EZ down tailgate, Weathertech front and rear floor liners, Black Westin 4" oval step bars
    Grab a multi meter and check which wire has a constant 12v...then turn the signal on and see if that one alternates voltage, use the wire that gets a constant 12v's
  7. Oct 12, 2012 at 5:35 PM
    #447
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
  8. Oct 12, 2012 at 6:03 PM
    #448
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    getting there with the fx-r's!
  9. Oct 12, 2012 at 11:51 PM
    #449
    jimbo808
    jimbo808 Well-Known Member
    Kapolei, Hawaii
    05 TRD Sport 4x4
    Debadged, Mbrp cat back turn down, Afe drop in filter, Icon extended travel, Light Racing ucas, Dakars, Icon 2.0 vs monotubes, 285/70r17 goodyear kevlar Mtrs, Morimoto Minis D2S' bhlm with blacked out bowls, Bamf Sliders, pelfrey single hoop front bumper, smittybilt X20 10k, pelfrey ifs skid, pelfrey trans skid, all pro rear with side plates, sway bar removed, front superbumps, Avec 20 inch light bar, rigid flood fogs
    just sealed mine up, need to adjust the lights too
  10. Oct 13, 2012 at 12:23 AM
    #450
    dibble9012
    dibble9012 Well-Known Member
    Received my FXR Stage III kit today. Everything is extremely high quality and wow these are bright (55w version)! I did a FX45 retrofit on my other vehicle and the FXR 3.0 far outperform those. Can't wait to get started!
  11. Oct 13, 2012 at 5:00 AM
    #451
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    Well I had some setbacks last night. As stated earlier I got them apart and painted the bezels. Letting them dry overnight and last night was going to put them back in. Before doing that I was working on getting the projectors mocked up in the reflector bowls. Grinding on that alignment ring, got it pretty close by eye. Go to check fit of the shroud, and wow, there is no way that is gonna work. The panamera shrouds are freaking huge. Wind up having to cut off more than half the length and the 2 little feet that stick out. Got one done then start on the other and totally screw it up. Yep, gotta order 2 new shrouds now :( So now I go back to the bezels. I pick one up and am looking at it and notice a few spots I missed. No prob, grab the rattle can and will just put one more light coat on it. As soon as the paint hits the bezel it starts to orange peel like I have never seen before! So yeehaw, I get to sand/remove all that today and start completely over.
    Anyway, I was ready to spit nails last night. More calm this morning. Heading to starbucks and then lowe's for more paint and paint remover. Then to put in an order for another set of shrouds. Gonna go with the apollo's to hopefully not have to do any cutting on them.
  12. Oct 13, 2012 at 10:16 AM
    #452
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    Back on track now. Copious amounts of acetone and elbow grease and I got all the paint off the bezel. Thankfully I only had to re-do one! Got it painted again and is now drying. Got one of the alignment rings modded and set in place with jb weld steel putty. Solid!! Lunch, then will get the other ring taken care of, then get the projectors mounted and secured and ready for my replacement shrouds.
  13. Oct 13, 2012 at 4:45 PM
    #453
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    Bezel is drying and is looking good. Thankfully!! Got both alignment rings modded and both projectors installed in the bowls. Both fire up and work great. Ran them for a few minutes to let them finish smoking, will do again before sealing everything up. Just waiting on my replacement shrouds to come in. All that is left is to paint the shrouds, install the halo's, then seal the headlights back up and re-install. Heading to vacation tomorrow, so I'll finish up next weekend. Take it sleazy gents, see y'all on the flip!!
  14. Oct 13, 2012 at 5:14 PM
    #454
    CayucosTacoma
    CayucosTacoma [OP] Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    glad you got it figured out! post some pics when youre done
  15. Oct 13, 2012 at 5:39 PM
    #455
    parboy
    parboy FORE!
    Brian
    Sherwood, AR
    Will do! Have you got yours finished up?
  16. Oct 13, 2012 at 5:50 PM
    #456
    Conman117
    Conman117 AWESOME MEMBER
    Nathan
    BC, Canada
    98 Brap-coma
    Blue LED dash lights
    Got mine yesterday. Pretty fast shipping to northern BC I must say. Props to TRS for that. Having some difficulty wrapping my head around the gatling shrouds, but I'll do more reading.
  17. Oct 13, 2012 at 7:03 PM
    #457
    CayucosTacoma
    2004 Double Cab 4x4
    no havent even started yet.
    What about them?
  18. Oct 13, 2012 at 8:01 PM
    #458
    PLC721
    Patrick
    Chandler, Az
  19. Oct 13, 2012 at 8:07 PM
    #459
    CayucosTacoma
    2004 Double Cab 4x4
    looks good! saw them on TW live
  20. Oct 13, 2012 at 8:08 PM
    #460
    PLC721
    Patrick
    Chandler, Az
    thanks man! i might have a serious problem though :mad:
Thread Status:
