Round 9 - HID Projector Retrofit Group Buy
Discussion in 'Group Buys' started by ambiguous, Aug 13, 2012.
Thread Status:
Not open for further replies.
  1. Aug 13, 2012 at 12:07 PM
    ambiguous
    ambiguous [OP] Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    the coupon is live: R9TacomaWorld25
    25% off:
    FX-R Stage III/IV
    Mini H1 Stage III
    Mini D2S Stage III
    Lexus RX-AFS Stage III/IV
    Gogogogogo!
    __________________
    Got a reply from Andrew @ The Retrofit Source and round 9 is a go. Link to 4runner forum thread:
    http://www.theretrofitsource.com/index.php
    Here's the basic if we want to get this round 8 going.
    -Stage III OR Stage IV complete kits
    -no CBI's/SVS discount
    -25 orders = 25% off
    -ships when 25 orders are completed
    -discount code will be posted once 4runner and tacomaworld forum has listed 25 people committing to buy
    info posted by buzzardsgottaeat
    A lot of people get the mini (H1 or D2S) because they're easiest to install
    FX-Rs are better quality but require free hand cutting of your light housing and a slightly more difficult aiming/securing process.
    Blazers are for fogs, you have to cut/rig it up custom, no plug n play or bake n reseal there.
    H4 headlights
    H10 fogs (H11 for 2012s) are the sizes you need and the harness will be the H4/9003 iirc
    H1 has been deemed a little brighter while D2S more even output. Most go with the H1 simply because its brighter but don't consider other factors. Matt and the guys at TRS mostly favor the D2S and I also like to point out that the larger shrouds fill our headlights better than the mini H1 and there is a greater selection.
    3000k is yellowish and good for fogs for its ability to cut through adverse weather
    4300k is like sunlight or stock color headlights and has the highest lumen count (brightest) of the available options
    5000k will be whiter and is the highest TRS recommends.
    6000k is also very white with a tiny bit more blue
    Any higher temp is stupid because you lose light output and fatigue your eyes and others.
    I always say 4300k is the way to go but can see how white/5000k has an appeal
    The upside to a projector retrofit vs cheap hid bulbs in your stock light housing is mainly that it is higher quality and has a clean cut off line.
    I can't think of anything else off the top of my head but that should be a good starting point for anyone who wants to start researching these.
    please add your name to the most recent list.
    1.ambiguous - Morimoto Mini (D2S) STAGE III KIT
    2.
    3.
    4.
    5.
    Keep in mind it doesn't really matter what kit you get, right now we just need the members that are committing to buy, once we complete the 25 TRS will give us the coupon code and we can use that 25% coupon code for any of the stage III or stage IV kits.
    Picture below is omac5's FX-R retrofit. (let me know if you want picture taken down)
  2. Aug 13, 2012 at 1:26 PM
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Confirmed. Ready to rock when we hit 25.
  3. Aug 14, 2012 at 9:42 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Group buy is for any complete stage 3 or better kit from what I've gathered in past. The ones you listed should all be included in the group buy although I have not seen a retrofit with the Lexus projectors yet. The more popular options are the FX-R and Morimoto mini kits.
    The Morimoto kit will be easier to install, but the light pattern won't be as nice as the FX-R kit (it will still be pretty damn good though).
    There is a little bit of a debate over which is better between the Morimoto Mini H1 vs. D2S kit. The H1 kit is supposedly brighter but the D2S kit has more even light across the width of the beam.
  4. Aug 14, 2012 at 9:56 AM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    Damn, although i do like my d2s i would really like the fxr's or better. MOre money gonna b leavin my wallet i guess
  5. Aug 14, 2012 at 10:15 AM
    Pugga
    Massachusetts
    Yeah, that's pretty accurate. I've got the 5K in my motorcycle and that's a fair assessment of their color, very white. 6K will put you into the more bluish range.
    The H1's seem to create more of a hot spot across the cutoff so you end up with a brighter section of light. The D2S seem to more evenly spread the light across the beam pattern. People swear by either one so it comes down to personal preference. Check out HIDplanet or google D2S vs H1 and you'll find some good pictures showing the difference.
  6. Aug 14, 2012 at 10:30 AM
    slingshot5r
    slingshot5r Well-Known Member
    Fort Polk, LA
    12 DCSB
  7. Aug 14, 2012 at 10:31 AM
    MySilverTaco13
    MySilverTaco13 Well-Known Member
    HBSoCal
    2012 Trd sport PreRunner
    fx-r all the way best quality although the minis are almost as good as the fx-r
  8. Aug 14, 2012 at 10:47 AM
    Pugga
    Massachusetts
    FX-R's are the best quality that's readily available and relatively easy to install. Not even close to the best all around when you start looking at some of the other projectors. The others take a lot more work to install though and can be hard to find (and pricey when you do find them).
  9. Aug 14, 2012 at 12:28 PM
    slingshot5r
    Fort Polk, LA
    12 DCSB
    Thanks for the help ambiguous!
    Interested in the BI-XENON MORIMOTO MINI STAGE III KIT (D2S) 5,000K
  10. Aug 14, 2012 at 12:34 PM
    AsianAnts
    AsianAnts just an AnT
    AnT
    Southern California (San Diego County)
    2011 PreRunner TRD Sport L/B Grey Metallic
    -Satoshi Grille Upper/Lower/Triangles -LED Map Lights, LED Dome Light, LED License Plate Lights -No front license -Wet Okole -Weather Techs (digi) -Running Boards -Bed Extender -AFE Cold Air Intake 2SI Dry Filter -Tailgate Hose-Clamp Mod, Tailgate washer Mod -Combi chain lock on bed extender -no chime w/ key in ignition & open door -Fog Light anytime -Slim Cubby's 3kHID fog -bumper plugs -keyhole plug -TRD license plate frame -combi-lock storage -rear TSB -window tint -camera mod -Painted radiator/engine covers -LS460 RetroFit -Bed Tie-Downs -LED Gauge Cluster, radio, clock and AC -Bed Mat -Extra DRings -Painted center console, radio unit, ac panel, overhead console.
    wow another one :)
  11. Aug 14, 2012 at 12:35 PM
    AsianAnts
    AnT
    :cool:
  12. Aug 14, 2012 at 1:50 PM
    Pugga
    Massachusetts
    Are you doing the retrofit?
  13. Aug 14, 2012 at 1:53 PM
    jblaze805
    jblaze805 Well-Known Member
    Ventura/Fresno, CA
    04 trd pre-runner
    2.5" king coilovers, caburg uca, magnaflow exhaust, aem intake
    2.
    3.
    4.
    5.
  14. Aug 14, 2012 at 2:03 PM
    AsianAnts
    AnT
    oh nada... jerez doing your retro?? :D
    not i hehe... or not that i am aware of:p
  15. Aug 14, 2012 at 2:17 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Smart man Anthony is...lol
    Naw I didn't tell him just asked him and he put 2 and 2 together ;)
  16. Aug 14, 2012 at 2:32 PM
    AsianAnts
    AnT
  17. Aug 14, 2012 at 2:45 PM
    ambiguous
    Burt
    2012 DCLB TRD
    2. ryanjboutin - Morimoto Mini Stage III (H1), 5000k w/white halos.
    3. slingshot5r - BI-XENON MORIMOTO MINI STAGE III KIT (D2S) 5,000K
    4.
    5.
    Keep adding please.
  18. Aug 14, 2012 at 2:53 PM
    ambiguous
    Burt
    2012 DCLB TRD
    You'll want a h4 relay kit.
  19. Aug 14, 2012 at 3:01 PM
    FCdrifter
    FCdrifter Well-Known Member
    Count me in for a stage 3 mini D2S in 4300.
  20. Aug 14, 2012 at 3:19 PM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    I'm down. Not sure which kit but it would be nice to know the pricing with the 25% off. Guess I could just check the website later huh :cool:
Thread Status:
