Routine Use of Emergency Brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rjtoc2, Jan 12, 2020.
  1. Jan 12, 2020 at 4:06 PM
    rjtoc2
    rjtoc2 [OP] Burglar of Turds
    Dallas/Fort Worth
    2008 Double Cab Prerunner SR5 (Super White)
    I routinely set my e-brake when parking - especially on an incline. Is there a downside or drawback to this?
  2. Jan 12, 2020 at 4:09 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    07 AC 4x4 V6 6MT
    -Bilstein 5100s @1.75" -16x8 SCS Ray10s with 305/70R16 General Grabber AT -CMC -URD Short Throw Shifter -Bed stiffeners -Bed mat -Aftermarket head unit -AFE Rebel exhaust -ME-SO Customs dome/map lights -Window tint with eyebrow -OEM LED 2015 tail lights -GTR Lighting headlight bulbs -Husky floor liners -Camper shell -Sumo Springs -Air intake -Aftermarket Volkswagen key fob -Aftermarket A/C knobs -Aftermarket LED license plate lights -Console organizer -JBA High Caster UCAs
    Nope, except that you have to use your muscles twice more than if you don't:boink:
    I have a 6 speed and the brake goes on every time it's parked regardless of terrain or slope.
    markgphoto, TomTwo and Marc70 like this.
  3. Jan 12, 2020 at 4:15 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I use the brake all the time in my autos. Helps keep the stress off the parking pawl. And it also keeps the e brake from seizing up. (And keeps the rear drums adjusted if you let it roll back just a wee bit while you pull it)
    Ccrames2018, OutbackHack and KY_Rob like this.
  4. Jan 12, 2020 at 4:19 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Let me be sure I understand the question. You want to know if it is ok to use the parking brake when parking?
    maverick4x2, scocar, lynyrd3 and 6 others like this.
  5. Jan 12, 2020 at 4:23 PM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    LOL, Glad I'm not the only one.
    Yes, use it every time you park unless you have some strong reason to believe that it will be frozen stuck when you return and you're on flat ground. It's a safety thing for everyone else and it helps protect your truck's transmission if someone should bump it. You know you're supposed to cut your wheels when parked on a hill too right?
    Taco*Sauce06 and Tullie D like this.
  6. Jan 12, 2020 at 4:23 PM
    Empty_Lord
    Dan
    Right or left depending on if your facing downhill or uphill actually.
  7. Jan 12, 2020 at 4:23 PM
    rjtoc2
    Dallas/Fort Worth
    Are there any issues associated with using the e-brake routinely (i.e. all the time) when the vehicle is parked? But since you called it a "parking brake" (which it technically is), my question seems moot.
    Alexely999 likes this.
  8. Jan 12, 2020 at 4:28 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    It is good to use it. The cable works better with use, it protects the transmission, is required in some jurisdictions, improves your standing in an insurance investigation. If you are in your level garage after driving an ice storm or during a rapid drop below freezing you may want to leave it, but even then a few back and forths will free up most ice.
  9. Jan 12, 2020 at 4:31 PM
    Bajatacoma
    SC
    And facing uphill it changes depending on whether you have a curb or not. ;)
  10. Jan 12, 2020 at 4:32 PM
    Bajatacoma
    SC
    The only issue is that the cable(s) stretch over time and need to be adjusted. Small price to pay to protect your truck.
  11. Jan 12, 2020 at 4:34 PM
    gilligoon
    gilligoon Well-Known Member
    Goon
    Watoosa Ridge, GA
    2017 Quicksand TRD OR DCSB
    Bilstein, ICON, Mobtown, Southern Style, Warn, SOS, Nitto, ARE, Northstar
    In winter, if the drums are wet from rain or stream crossing, and temperature goes below freezing, the brakes can get stuck. Hasn't happened to me yet on the Tacoma, but I've had it happen on numerous other vehicles with rear drums. Used to happen pretty frequently when I had a creek ford on the driveway. I can't see it having any other negative effect.
  12. Jan 12, 2020 at 4:37 PM
    Marek71
    Marek71 Well-Known Member
    2019 TRD Sport DCSB
    Only drawback is if you forget to take it off before driving. Believe it or not I knew someone this happened too, the drag on acceleration and the smell finally queued him in.
  13. Jan 12, 2020 at 4:38 PM
    Empty_Lord
    Dan
    The bright red brake light didn’t alert him?
  14. Jan 12, 2020 at 4:40 PM
    Marek71
    2019 TRD Sport DCSB
    No, it was an older guy I worked with in my 20's we were making a run in the company van. It was hilarious.
  15. Jan 12, 2020 at 4:45 PM
    Markcal
    Markcal Well-Known Member
    I use my parking brake all the time when I have to make a quick stop/go.
    I have used it on some steep hills running in neutral with some weight in the bed and wonder how common is it for the parking brake to fail when parked like that? :confused:
  16. Jan 12, 2020 at 4:49 PM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    I always set my parking brake when parked. Seems like a smart thing to do.
  17. Jan 12, 2020 at 4:51 PM
    Woolybugger
    Woolybugger Well-Known Member
    Aaron
    2005 blk acess cab trd 4x4
    King coilovers
    I use it all the time probably out of habit because all my other vehicles are manual trans and setting the brake is mandatory.
  18. Jan 12, 2020 at 4:52 PM
    Bajatacoma
    SC
    Well hopefully you're also putting the transmission in 1st (manual) or park (auto) along with using the parking brake. If it's properly adjusted, it should hold the vehicle on a steep hill but that doesn't mean I'd trust it by itself.
    markgphoto and jungleman like this.
  19. Jan 12, 2020 at 4:54 PM
    eon_blue
    Azusa, CA
    I've done it before...hop in the truck to go quick and forget to release the brake. One time I did it on the trail in 4lo and it bent the metal brackets up on the rear axle that hold the ebrake cable in place lol. Had to pound them back down with a hammer.
  20. Jan 12, 2020 at 4:55 PM
    Markcal
    I usually leave it in neutral if it's a quick stop, but think from now on I will turn off the engine and put it in 1st gear then use the parking brake, being a 2006 and 13 years old.
