Routing wire from rear tailgate to dash
Discussion in '3rd Gen. Tacomas (2016-2023)' started by theandyj, Jun 12, 2019.
  1. Jun 12, 2019 at 12:30 PM
    theandyj
    theandyj [OP] Well-Known Member
    Orange County, CA
    2019 Cement OR
    If I wanted to run a wire (from a DVR camera) from, let's say the rear license plate to inside the cab (i.e. dash) - what is the route of the cables that would be easiest to follow?
    I tried searching for this, but didn't quite find the details I was looking for. Thanks!
  2. Jun 12, 2019 at 12:37 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    there is a grommet you can enter the cab, below the drivers seat.
  3. Jun 12, 2019 at 12:38 PM
    sandiegohasthebesttacos
    sandiegohasthebesttacos Well-Known Member
    sdsponger likes this.
  4. Jun 12, 2019 at 12:42 PM
    MrWednesday
    MrWednesday Well-Known Member
    Colorado
    2018 DCSB TRD OR MGM
    Passenger side would be easier. Gas tank on the driver and is a PIA to run wire over.
    ShirtTucker likes this.
  5. Jun 12, 2019 at 12:44 PM
    MECtacoOR
    MECtacoOR Well-Known Member
    Michigan
    2017 Magnetic Gray OR DCSB
    Just under get under your truck and look for the factory harness is my best advice, a headlamp is nice for that. For me it was easy enough to follow the factory harness exactly and zip tie my new wire, in conduit, to that.
  6. Jun 12, 2019 at 1:22 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    I've run along both sides. The passenger side is much easier. Both sides have existing wiring that you can follow, and grommets that you can pass your wiring through.
    FLA_Hoosier likes this.
  7. Jun 12, 2019 at 1:51 PM
    theandyj
    Orange County, CA
    2019 Cement OR
    Awesome, thank you for the info!
