Routing wiring through double cab
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DangerPudge, Feb 17, 2021.
  1. Feb 17, 2021 at 4:17 PM
    DangerPudge
    DangerPudge [OP] Well-Known Member
    Lift, wheels/tires, Snugtop
    I've finally had a little time to get the light bar up and mounted on the cap (not cab) and planned on wiring from the console area (the junction is where the cupholders used to be, and located under a switch panel). I was curious to see/hear what methods you've done to route the wiring out of the cab, and either between the cab/bed or up through the bed. Surely folks have done it before and I'd rather learn from, than repeat mistakes.
  2. Feb 17, 2021 at 9:54 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
  3. Feb 19, 2021 at 10:05 AM
    DangerPudge
    I think that's where I made my harness exit as well. Just ahead of the under-seat storage cabinets dead-center of the hump. I punched a hole in the grommet, fed the wiring through, and sealed with RTV. Now I'm finally on to sound-deadening installations.
