Royal Purple Synchromax in Transfer Case
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zzz_sleepyRT, Apr 12, 2021.
  1. Apr 13, 2021 at 8:15 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    :eek::eek::eek:
    $60 a QUART!?
    That's highway robbery, I thought Amsoil was expensive.
    I mean I would run OEM or that other oil someone mentioned that meets the same spec if it was cheaper but holy cow I thought the 3rd gens had basically the same transfer case as the 2nds which is basically the same as the 1st which is hardly any different from the...
    Just wow, guess it's good you only need like 2 quarts.
    Toyota's got y'all 3's by the shorts ones eh?
    Might actually be worth sending to Blackstone for analysis to find something similar.
    Skydvrr and RustyGreen[QUOTED] like this.
  2. Apr 13, 2021 at 8:24 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I don't worry much about the gear oil for the differentials, but from what i've heard, and seen of these gen3 tacos...beware of what you use in the transfer case, and automatic transmission.
    Skydvrr likes this.
  3. Apr 13, 2021 at 8:29 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    It takes 1 quart exactly.
    I'm not happy with the price but if you consider how often you change it verses the cost of the truck I don't feel it really is that much money for the piece of mind.
    Off topic: Your avatar could be my dream girl :thumbsup:
    Key-Rei[QUOTED] likes this.
  4. Apr 13, 2021 at 8:35 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The manual transmission calls for a 75W-90 gear oil (common viscosity) -- but in a GL-4 grade (easy to get but not on most store shelves), this is an important specification. No oil with a GL-5 rating is correct. Again, most folks overlook or don't understand the reason for the specification.
    Skydvrr, maxtherat and Key-Rei like this.
  5. Apr 13, 2021 at 8:39 AM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Yeah another vote to change it. I like RP products but I don’t think syncromax meets the OEM specs for your transfer case. That stuff is mainly meant for manual transmissions. Probably yellow metal safe.
    Key-Rei likes this.
  6. Apr 13, 2021 at 8:39 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    The VOAs have been done...
    You can find similar stuff as far as viscosity; it's the additive package that's missing. It's measured in thousandths of ppm; Ravenol, for example is measured in hundredths of ppm.
    Granted, LF is a highly fortified mineral whereas equivalents are usually group 3+ or 4 synthetic. This may make additive comparisons a wash.
    Point is...there's nothing like LF.
    ETA: I've heard the claim that Redline PSF is the closest thing you can get...on paper.
  7. Apr 13, 2021 at 8:39 AM
    Key-Rei
    Key
    Florida
    It's cause the sulfur content in the GL5 spec likes brass synchros a little too much.
    But diffs and transfer cases don't have parts like that.
    I run gl4 in my transfer also due to paranoia of fluid cross contamination between the mated cases.
    RustyGreen[QUOTED] likes this.
  8. Apr 13, 2021 at 8:42 AM
    maxtherat
    Inland Northwest
    This is absolutely correct. Most GL-5 oils are not compatible as they cause premature wear to the soft, yellow metals. Funny enough RP advertises that their GL-5 gear oil is yellow metal safe.
  9. Apr 13, 2021 at 9:03 AM
    RustyGreen
    sleeping in a chair
    Pavement Princess
    The Syncromax is recommended for manual transmissions that call for an automatic transmission fluid, it carries no GL rating so not for use in a manual transmission that calls for a gear oil.
    maxtherat[QUOTED] likes this.
