RP-342 cosmoline.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kruuuzn, Sep 26, 2020.
  1. Aug 6, 2023 at 4:53 PM
    #121
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    I use to use fluid flim on my tundra, living in connecticut...right in the center of the salt belt. I got tired of doing it every fall, only to see it washed away by late march with areas on the frame starting to show surface rust. I did this tacoma when new using cosmoline rp-342. No more every year doing the job over. I guess if you live in drier parts of the country, fluid film is ok, but it gets way too wet up here.
    Tacomuncher21 likes this.
  2. Aug 30, 2023 at 5:21 AM
    #122
    dietcokefiend
    dietcokefiend Well-Known Member
    With it being summertime I'm checking on my existing cosmoline application. Overall seems pretty good after one season. I found a few light areas that have some orange dusting that I plan to lay more RP-342 into. It's a few bracket areas and a couple seams. Probably missed in the first go this winter.
    Question for you guys. After I clean the underbody, should I use any iron/rust converter to hit those flash rust spots before more cosmoline on top?
  3. Aug 30, 2023 at 5:51 AM
    #123
    zoo truck
    None
    When I noticed a couple orange spots on the rear leafs inside the rear wheel wells a year later, I just hit them with 2 coats of cosmoline. Idk, if I totally sprayed them good initially, but it s been 2 years since, and I can't find anything else I missed. This stuff is permanent. I can do other things like worry when should I change my oil next.
  4. Aug 30, 2023 at 6:57 AM
    #124
    dietcokefiend
    Yea my initial application was mostly good, but it was middle of winter in my garage before snow/salt hit. Needed to get the majority done but missed some various small spots.
  5. Aug 30, 2023 at 8:29 AM
    #125
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I would say yes, or at least that’s what I do
  6. Aug 30, 2023 at 8:36 AM
    #126
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    How are you guys protecting the internal parts of the frame where you need a long application house to get it covered? It seems like those areas are most prone to road salt/chemicals getting stuck and rotting without showing until it’s too late.
  7. Aug 30, 2023 at 8:44 AM
    #127
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it has some corrosion protection from the factory on the inside
    usmc2msu[QUOTED] likes this.
  8. Aug 30, 2023 at 8:48 AM
    #128
    dietcokefiend
    I did't pop off the plastic covers to go into the transmission boxes yet, but usually, the straws shooting at it works well. You can also get like 3-foot-long universal spray straws to cut to length to get deeper inside.
  9. Aug 30, 2023 at 9:50 AM
    #129
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    I coated mine with the rp-342 around this time last year with 5k miles on the truck and played in the snow a fair bit this past winter including pushing through drifts that were taller than the frame. I put an extra coat on the bottom rails and the back side of the rockers for the initial application because of the bi-annual chip-n-seal of the roads in my area. I also applied it heavy on service points like shock mount/suspension bolts and nuts, etc.
    15k miles later and no signs of rust or bare spots. It's dusty looking with a lite-brown tint from a few wet camping trails, but it's holding up very well. May get under it this weekend and get some photos. Deciding if a drain and fill on the trany is worth it at 20k miles.
    I also covered the fill and drain plugs well on 1st application. When I did drain and fill both diff's at 15k miles, all the plugs came out with zero fuss vs. some of the crusty / frozen diff and transfer case plug stories I've read on the forum. After I was done and wiped off the drips, I put a fresh coat of the rp-342 back over to seal them again. The oil and well as mineral spirits does cut the rp-342 quickly if you need to remove it.
  10. Aug 30, 2023 at 9:57 AM
    #130
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    If you are using rattle cans, you need an extension like this:
    https://www.amazon.com/DU-MOST-Extension-360-Degree-Corrosion-Protection/dp/B0BRJNFDR8
    I flush mine out after use by spraying some WD40 through it so it doesn't get gummed up from the rustproofing product.
    I would also suggest doing a test spray into a clear plastic soda bottle to assess the coverage that you are getting.
  11. Aug 30, 2023 at 12:02 PM
    #131
    zoo truck
    None
    I could be wrong, but that extension will not adapt to the rp-342 cosmoline rattle cans if used. They have an odd nozzle. Years ago I found one to fit from eBay, it arrived with no visible brand name packaged in a plastic bag like someone had specifically made them just to fit their cans. I can't even recall the seller.
  12. Aug 30, 2023 at 2:35 PM
    #132
    RichVT
    Rich
    Northern Vermont
  13. Aug 30, 2023 at 7:19 PM
    #133
    LexTech2018
    LexTech2018 Active Member
    2023 Celestial Silver Off Road
    Finally decided on which undercoating to put in the truck and was looking to do in the next few weeks. Just went to purchase some aerosol cans of this stuff but it's not even popping up on Amazon anymore. Cosmoline direct website showing backorder.
    Have any of you purchased recently and if so where from? I'm willing to order from Cosmoline direct but fear it wouldn't show up until it's too late.
    BBogey likes this.
  14. Aug 30, 2023 at 7:58 PM
    #134
    dietcokefiend
    I saw the back order mention, it's like one week delay.
  15. Aug 30, 2023 at 8:09 PM
    #135
    Thegrassisalwaysgreener
    Thegrassisalwaysgreener Well-Known Member
    Manitoba
    I did 90 percent of my frame with some loctite pc 9660 maxi coat the other day on my new truck that I had from work. It looks to be the same stuff, heavy amber colored wax coating. I ordered a few cans of heavy formula rp-342 and I still have a couple cans of loctite brand. Planning on finishing the job on my off days. I did my old colorado with fluid film regularly and it still rusted where it got blown off by slush and salt in winter. This seems like a much better solution to the rust problem we have with Canadian winters.
  16. Aug 30, 2023 at 8:10 PM
    #136
    Manitoba
    Got mine from Amazon
  17. Aug 31, 2023 at 4:13 AM
    #137
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    I bought a gallon of 342rp from Cosmoline Direct and used it on my brand new '23. Went on great and seems to be working as desired but it hasn't seen winter yet. Only issue I have with it is the price. I think living in Canada we get RAPED with exchange and charges. I paid $145 CAN with exchange for the Cosmoline, and FedEx charged me another $50 to ship it! Kinda pricey if you ask me. Anyways, I researched and found a company called Commercial Oil in Hamilton ON. Speaking with their sales guy and reviewing the few different undercoatings they offer, I'm heading there on Friday to pickup a 5 gal pail of Rust Preventative #1 for $200. As per the spec sheet it's a similar product to Cosmoline- an amber colored solvent cutback rust preventative. I hope that it is similar enough that there isn't any unwanted interactions between them. I'll report back my findings.
  18. Aug 31, 2023 at 4:31 AM
    #138
    zoo truck
    None
    I purchased a pack of 9 cans off eBay when there was a fair deal that a seller had years ago where the price of the product plus shipping came out very close if buying direct. Haven't had any need to buy more. Buying direct, you'll find the overall cost as good as anywhere else.
  19. Sep 3, 2023 at 1:56 PM
    #139
    petethemeat
    Pete
    Ontario
    2023 TRD OR AC MT
    Today, I added some of Commercial Oil's Rust Preventative #1 to some areas that we're not well covered by my Cosmoline job This stuff is a bit thicker than Cosmo, I had to thin it to spray out the siphon gun. I added varsol paint thinner as the freshly opened can had a distinct scent of it. I compared the dried product to cosmo and it is practically identical. Color, odor and consistency was so close you couldn't tell them apart. Where I oversprayed the cosmo with RP#1 there was no difference once it dried. If you're looking for a source of "cosmoline" in Canada for a way better price look up Commercial Oil in Hamilton. I have no affiliation with them, they just provided good service when I ordered and when I picked it up. I'll report back on this thread in the spring to say how well it held up to this winter's salt and brine.
  20. Sep 8, 2023 at 11:48 AM
    #140
    z28sasg0
    z28sasg0 New Member
    Hi -- First post. I'm reading this cosmoline post with interest -- trying to fight off rust here in the Midwest. Are you guys spraying cosmoline on your suspension springs? Or are you using some other product on springs? Just wondering how the cosmoline holds up on the springs since they can obviously flex. Thanks!
