rpm at 65mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MacT66, Mar 16, 2009.
  1. Mar 16, 2009 at 4:01 PM
    MacT66
    MacT66 [OP] Active Member
    09 DC 4x4 defective springs toyota wont fix
    Topper, Bed Rug, factory weak,mushy, rear springs
    What should the rpm be for a 09 DC LB automatic in 5th gear at 65mph?
  2. Mar 16, 2009 at 4:03 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    around 2k
  3. Mar 16, 2009 at 4:07 PM
    MacT66
    That is what I thought and swore that what it has been but driving home today it stayed at 2,500 rpm on flat road and even downhill. I think it is staying in 4th gear.
    Is there a overdrive button hidden somewhere or another reason for it to not go into 5th? I did not have a load nor towing anything.
  4. Mar 16, 2009 at 4:09 PM
    tacoskim
    Los Angeles, CA
    Stock
    d is the overdrive
  5. Mar 16, 2009 at 4:10 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    When you have it in (D) it should go into 5th gear. If you move the lever to the left it will stay in 4th gear. RPM on mine is right around 2000 at 65.
  6. Mar 16, 2009 at 4:10 PM
    tacoskim
    Los Angeles, CA
    Stock
    sometimes when the truck is not warmed up yet, itll keep higher rpms, its the computer doin its work, supposed to warm up the engine quicker
  7. Mar 16, 2009 at 4:14 PM
    MacT66
    bingo! my wife bumped the lever to the left. Is there any dash indicator when this happens? the light in the dash had "4" lighted.
  8. Mar 16, 2009 at 4:23 PM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    Thats is the indicator, if put in D it will have the D lit up.
  9. Mar 16, 2009 at 5:10 PM
    MacT66
    that makes sense. thanks!
