rpm fluctuates at idle
Discussion in '4 Cylinder' started by PeterNM, Apr 15, 2010.
  1. Apr 15, 2010 at 4:13 PM
    PeterNM
    PeterNM [OP] Active Member
    New Mexico
    97 Tacoma LX, 4X4, 248,000m
    AFE Drop-in
    i recently changed my spark plugs, but not the wires, (it's happening this weekend). the weirdest thing is my temp gauge has started occasionally go up and down....i checked my coolant level in the overflow tank and it was good......the only things that i've worked on in the past months: new belts, plugs, oil.....
  2. Apr 15, 2010 at 8:39 PM
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    have you cleaned your throttle body?
  3. Apr 15, 2010 at 11:21 PM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2009 Tacoma Regualr Cab 4x4 2.7L
    Seafoam it.
  4. Apr 15, 2010 at 11:31 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    Hmmm, the temp thing is odd, but did you double check any and all vacuum lines you may have disconnected or bumped or damaged or reconnected incorrectly when you were doing the other work? They can cause idle problems.
    When does the temp fluctuate? While driving at constant speed, or at idle? And by how much? This could merely be coincidence.
    When was the last time the coolant was changed? Maybe it's time to do that, and replace the thermostat and even possibly hoses that may be collapsing and impeding flow. This happened to my old truck at highway speeds.
  5. Apr 16, 2010 at 8:41 AM
    btkicker
    btkicker Well-Known Member
    Denver
    '10 4x4 Reg Cab Manual
    For the temp thing, change out the thermostat. Fast & Easy.
    For the rough idle...check for cracks in you rubber air intake pieces...and of course vac lines. 99% sure that what it is, an air leak caused by you removing the pieces when you went to change the plugs.
  6. Apr 16, 2010 at 12:24 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    my idle is a little below 500 rpm when its properly warmed and relaxed :)
  7. Apr 16, 2010 at 12:30 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  8. Apr 23, 2010 at 11:11 AM
    PeterNM
    New Mexico
    AFE Drop-in
    thanks for the replys i will seafoam, clean the iac, and flush fill...it's great to check with rest of the world to make sure i'm not missing anything.
  9. May 2, 2010 at 8:04 PM
    2000yota
    2000yota Toyota FTW
    Garrett
    Hernando, MS
    2006 TRD Sport
    a few weeks ago one of my spark plug wires went out and i didnt know it the rpm went down under 500 at idle and would make a bad noise, this may be your problem i replaced the wires for about thirty bucks and it was runnin great afterwards. FYI: dont touch the wires while the truck is runnin. hahah itll give you a bad shock
