RPM Flucuations With Steering
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DRETACO, Nov 24, 2016.
Thread Status:
Not open for further replies.
  1. Nov 24, 2016 at 8:46 PM
    DRETACO
    DRETACO [OP] Well-Known Member
    17' TRD V6 DCOR AT
    Hi TW. Bought my first DCSB V6 in sept. Have ~2500 mi now. I have some of the same tranny issues noted on the forum despite having the TSB performed when I bought the truck.
    The truck has an annoying tendency to accelerate slightly when turning the wheel. Only noticed when slow speeds in reverse or drive. Not a huge deal but definitely suprises you if you're not used to it. It may be a "normal" thing but my old Silverado didn't do this. Hope someone can enlighten me. Posted a video to help explain symptoms. Thanks.
    https://youtu.be/G100Pffqbd0
  2. Nov 24, 2016 at 8:52 PM
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Power steering.
    P/S pump adds load to engine, engine adds RPM to idle to compensate.
    Happens on every car and truck with power steering but for some reason it's particularly exaggerated on the V6.
    EDIT: some cars/trucks don't bother compensating so you notice a drop in RPM instead.
    vinkon235 likes this.
  3. Nov 24, 2016 at 9:04 PM
    NosBigShot
    NosBigShot Well-Known Member
    Charleston Oregon
    93 Bronco , 2016 Taco
    Mine has tried to kill me with no steering wheel input. I have run into my house. I've slammed my trailer and knocked it off the blocks . It's tried to stuff me into the back of cars in the drive thru. Rapid acceleration. 800 RPM to 1,000 or 1,200 RPM. Sometimes when I'm coming to a stop it will push through the brakes. Toyota knows.
  4. Nov 25, 2016 at 5:25 AM
    DRETACO
    17' TRD V6 DCOR AT
    I figured it was the p/s pump. I suppose this is not something that can be fixed then?
  5. Nov 25, 2016 at 6:58 AM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    How rapid can it be with a 200 RPM boost?
    Herniator likes this.
  6. Nov 25, 2016 at 7:02 AM
    Nfarrall
    Nfarrall Well-Known Member
    Chester county, PA
    2017 QS DCSB SR5
    lol wut?
  7. Nov 25, 2016 at 7:08 AM
    TacoMan2017
    TacoMan2017 Well-Known Member
    It's called electronic steering...
  8. Nov 25, 2016 at 7:10 AM
    Balockay
    Balockay Well-Known Member
    Blake
    Cleburne, TX
    2017 4Runner TRD ORP
    Just look at the build thread
    Fixed? There's nothing wrong with it. Its doing what it was designed to do.
  9. Nov 25, 2016 at 7:39 AM
    Nfarrall
    Chester county, PA
    2017 QS DCSB SR5
    the truck still uses hydraulic steering...
    Herniator and Aussiek2000 like this.
  10. Nov 25, 2016 at 7:56 AM
    DRETACO
    17' TRD V6 DCOR AT
    It's not terrible, just annoying. I must apply increased brake pressure to compensate for the surge. No other vehicle I've driven has done this. Thanks for your input. I will just live with it.
    arnette64 likes this.
  11. Nov 25, 2016 at 9:09 AM
    NosBigShot
    Charleston Oregon
    You sit in your truck ... comfortable like and with enough brake pressure to hold it still and have it flash 200 to 400 RPM and tell me how rapidly it takes off.
  12. Nov 25, 2016 at 9:22 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    The the OP, GM doesn't compensate engine speed with P/S except for some old models. So trying to compare your tacoma to an old silverado is not valid. 2014+ silverado 1500's have electric streering
  13. Nov 25, 2016 at 9:34 AM
    DRETACO
    17' TRD V6 DCOR AT
    Yeah.. So my father's 2016 Silverado doesn't do that either, at least not to the point of the truck surging forward. I'm assuming based upon the response here that nearly everyone has this and doesn't annoy most. I like the truck too much otherwise to sell it. I will continue to brake carefully:).
  14. Nov 25, 2016 at 9:35 AM
    Aussiek2000
    2016 Offroad AC
    2016 has electric steering, not hydraulic like a taco
  15. Nov 25, 2016 at 9:38 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    WTH just happened in here? :confused:
  16. Nov 25, 2016 at 9:47 AM
    MOC221_
    Frank
    All righty then.. Life's too short bud, had a co-worker almost die yesterday.. heart attack. He is 41 yrs old. Perspective.
    Frank
  17. Nov 25, 2016 at 9:53 AM
    MOC221_
    Frank
    Yeah that looks perfectly normal.
    TBH, my idle speed is affected more than that by the AC compressor cycling. Oh, and by pressing the brake pedal when the engine is cold - that makes the RPM rise quite noticeably.
    Frank
  18. Nov 25, 2016 at 10:01 AM
    NosBigShot
    Charleston Oregon
    Mine has been good kinda lately... it still dangerous.
  19. Nov 25, 2016 at 10:11 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Normal, it'll do the same when the A/C compressor kicks in too. As said, load will cause RPM increase to compensate.
Thread Status:
