RPM @ Idle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Winch, Oct 16, 2020.
  1. Oct 16, 2020 at 7:49 AM
    Winch
    Winch [OP] Well-Known Member
    2019 TRD OR MT V6
    None yet
    Is it normal for the idle to go from 600 to 900 and waver back and forth? Almost like when the AC compressor kicks on.
    MOC221_ likes this.
  2. Oct 16, 2020 at 8:01 AM
    Blackfoot
    Blackfoot Well-Known Member
    2020 TRD Sport Midnight Black 4X4
    Nope, mine is steady as a rock
    kahanabob and Winch[QUOTED][OP] like this.
  3. Oct 16, 2020 at 8:26 AM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    Engine up to temp?
    Was the defrost on?
    If it's oscillating like that constantly, that's not normal.
    If the engine is not up to temp and you apply the brakes (clutch in), the rpms will rise from idle and hold until you take your foot off the brake pedal. This is on OR and PRO with fancy electric/hydraulic brake booster. Pretty much goes away when up to temp.
    Also you'll get a lil spike when you begin to turn the steering wheel.
    Just throwing experiences out there..
  4. Oct 16, 2020 at 8:57 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Might be normal if a cold engine. Idle on my 3.5 v6 will pluse from 800 to 1200 when cold and outside temps are around 50 degrees F. Once the engine temp gauge gets up to norm, its a rock solid steady 800 rpm...at least till the ac is turned on.
    Winch[OP] likes this.
  5. Oct 16, 2020 at 8:59 AM
    Kev250R
    Kev250R Well-Known Member
    Kevin
    Orange, So.Cal.
    2020 Tacoma TRD Off-Road 6MT
    Floor mats, junk in center console
    Normal. It’s just the engine compensating for when the A/C compressor engages.
  6. Oct 16, 2020 at 9:01 AM
    Winch
    2019 TRD OR MT V6
    None yet
    But this with the AC off. I know it increases with it on.
    Junkhead likes this.
  7. Oct 16, 2020 at 9:03 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Any input on the steering wheel? I believe there's a pressure sensor on the power steering that bumps up the idle as well.
    Junkhead and Winch[QUOTED][OP] like this.
  8. Oct 16, 2020 at 9:04 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Any load that gets added will increase the RPM's. Power steering when turning the wheel, AC compressor when AC is turned on, engine fan turning on, etc. As things turn on and off, you'll see it move around. I wouldn't consider it an issue to be honest.
    Chew, Garyji, Winch[OP] and 1 other person like this.
  9. Oct 16, 2020 at 9:07 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ok....quick question.....
    Can you hear the engine change speed or just looking at the tachometer?
    If your tachometer is fluctuating without the engine changing speed, then you have an instrument problem.
    If the engine is actually fluctuating, then the problem is much deeper and may need a dealer to solve. Assuming there are no input changes, such as AC on, turning steering wheel....etc.
    wahoobie and Winch[OP] like this.
  10. Oct 16, 2020 at 9:16 AM
    Spraynard
    Spraynard Priapism survivor
    hagrid
    Pittsburgh
    '19 AeroTundra PRO
    The defroster will cycle the AC compressor too.
    Junkhead, Chew, wahoobie and 2 others like this.
  11. Oct 16, 2020 at 11:01 AM
    Winch
    2019 TRD OR MT V6
    None yet
    I hear the engine. Gauge seems ok.
  12. Oct 16, 2020 at 1:27 PM
    zoo truck
    None
    Its likely normal if the outside temps are around 50 f or so. It should all stop once the engine is up to normal operating temperature. This provided the ac/heater fan is off.
  13. Oct 16, 2020 at 1:29 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Tatie your foot off the pedal ...lol
  14. Oct 16, 2020 at 1:37 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you want to deal with this at home, you could try pulling off both of the battery terminals (negative off first and on last) and touch them together for a few seconds. That will do a decent system reset. You'll have to redo some minor settings in the radio.
    If that doesn't work, you can do a Learned Value Reset with TechStream and a 5min idle. That will give your ECU a clean slate to learn from. You'll need a good USB OBD adapter for that, like a Tactrix, or a helpful person in your area.
    The other potential, besides a loose connector or hungry rodents, is a dirty AMM. There are cleaners that you can get at autoparts store. Read the instructions carefully as not following them can destroy an expensive sensor.
    If you're not up for all that, then dealer? 50:50 on them saying that it is normal, though I can assure you that it is not.
  15. Oct 16, 2020 at 1:59 PM
    Winch
    2019 TRD OR MT V6
    None yet
    I'm gonna observe this situation and make sure that I've got all the bases covered, e.g., normal temp, fan off, etc.
    Junkhead and tonered like this.
