Rpm jump
Discussion in '1st Gen. Tacomas (1995-2004)' started by Hambone155, Mar 31, 2013.
  1. Mar 31, 2013 at 10:15 AM
    Hambone155
    Hambone155 [OP] Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    On the interstate truck overdrive light will flash
    Over drive will jump in and out.
    code is for trans speed sensor fault
    I've replaced the trans (220 on it and fluid was burnt)
    Replaced speedo cable and sensor. Cable was broken.
    Is this a mechanical or electrical issue?
    Has anyone had this happen to them?
    Thanks.
