RPM/noise increase during the first few seconds of driving
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheTopDog, Jun 12, 2025 at 8:11 AM.
  1. Jun 12, 2025 at 8:11 AM
    TheTopDog
    TheTopDog [OP] New Member
    2021 Lunar Rock Tacoma TRD Pro
    I've noticed that when I first start driving for the day (or after several hours) my engine seems to rev up a little bit for a few seconds usually at 5-10 mph when I'm leaving my driveway. It's almost as if the engine is "working harder" briefly, but there isn't any surge in power or power loss really. It's more like excessive noise then it goes away.
    is this normal? It does it with and without an idle warm up. I'm guessing this is some sort of cycle the truck is running when it first goes in drive. Has anyone else experienced this?
    2021 TRD 4WD, 55,000 miles.
  2. Jun 12, 2025 at 2:06 PM
    hellvetica
    hellvetica Member
    Los Angeles
    2020 TRD OR
    Following. Have the same thing happen. To me it sounds like a radiator fan kick on in a high setting if that makes any sense. It only occurs upon initially driving from a cold start.
  3. Jun 12, 2025 at 4:11 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    It's the mechanical fan clutch. They all do it after cold start as you rev up the engine initially.
    Speedfreak, Chew and t0p_d0g like this.
  4. Jun 13, 2025 at 2:46 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
  5. Jun 13, 2025 at 3:57 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    All vehicles do this and always have.
  6. Jun 13, 2025 at 7:48 AM
    hellvetica
    hellvetica Member
    Los Angeles
    2020 TRD OR
    Thanks all! My 2nd Gen didn’t do that (or at least not as noticeably).
  7. Jun 13, 2025 at 8:09 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    This ^^^
    The fan is hydro-mechanical and has a default to high when cold or failed. Once it is at operating temperature it reduces rpm until such time as it senses an over temperature and will ramp up as needed. This means it will be a bit noisier when you cold start the vehicle. If it doesn't do it, then you may have a fan clutch issue that needs to be addressed.
  8. Jun 13, 2025 at 8:54 AM
    TheTopDog
    Thanks!
    DTaco18[QUOTED] likes this.
