RPM on highway w/ 2.7????????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justaco, Feb 24, 2011.
  1. Feb 24, 2011 at 2:12 PM
    Justaco
    Justaco [OP] Member
    Justin
    St.Louis
    03 4WD Extra Cab SR5
    Ok i just recently bought a 2003 Taco with the 2.7 in it and i was wondering if it is normal for it to rev at 2400rpm at 60mph???
  2. Feb 24, 2011 at 2:29 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    at 65 mph im at 2300 to 2400 rpms. 70 im at 2400 to 2500. and 75 im usually at 2500 to 2700
  3. Feb 24, 2011 at 2:33 PM
    Justaco
    Justaco [OP] Member
    Justin
    St.Louis
    at 70 mine is at 3000 ha ha so i am wondering if the owner before me put different gears?hmmmm?
  4. Feb 24, 2011 at 2:38 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    Most likely that is about right. Toyota designed these engines to work optimally at 2200-3200 rpm.
  5. Feb 24, 2011 at 2:39 PM
    tacowade
    tacowade Active Member
    Wade
    deerwood,mn
    95tacoma4x4
    How many RPMs do you run at 55 MPH? What size tires do you have? What gear ratio do you have? I run 2000 RPMs at 55.
  6. Feb 24, 2011 at 2:51 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    ya im runnin about that too with 31's and stock gears
  7. Feb 24, 2011 at 2:51 PM
    Stuardoslls
    Stuardoslls Well-Known Member
    Stuart
    Hawthorne, CA
    2012 Double Cab 4x4 TRD Offroad Package
    Just Rims and Tires: FJ Cruiser 16" wheels w/ 265/75/16 BFG KO2's
    X2 thats right about where my truck revs
  8. Feb 24, 2011 at 3:15 PM
    Justaco
    Justaco [OP] Member
    Justin
    St.Louis
    yeah thats close to where mine is seems a little high but its a yota they no what there doing ha ha
