RPM on highway
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tanktodd, Dec 2, 2009.
  1. Dec 2, 2009 at 3:41 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    My old dakota with 3.9 axle and 235 /75/15 was 1900rpm at 65mph if i recall, maybe 2000, my 3/4 ton silverado was 2200@65, my dad's expedition is 1800 at 65 and tall 3 towed great too. But honestly I like my Taco, doin 65 at 2400 means nothing, each vehicle is what it is. Mine is 3500 lb rated, but I didn't buy it to tow.
    The OP said his is 3k at 75, I'm still wondering whats up with that.
  2. Dec 2, 2009 at 4:10 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    What tsb? Cause I'm at like 65 at close to 2.5k. At that speed I get 21ish when I do cc at 55 I get over 25mpg
  3. Dec 2, 2009 at 4:12 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    TSB only applies to the Auto tranny. You also have 4:10 rear gears, so that will keep your rpms a little higher than an auto with a V6.
  4. Dec 2, 2009 at 4:34 PM
    08pretaco
    az
    Just for kicks and grins what does the tsb do? Change gears or something?
  5. Dec 2, 2009 at 4:46 PM
    Tacoyota
    08 4wd
    I want a TSB some day. You 4.0/auto guys talk about em a lot so I guess you like them , right?:D
  6. Dec 2, 2009 at 9:04 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    the 5 speed manuals have a 0.805:1 overdrive...the 5 speed auto has a 0.71:1.....so with the 6 lug gearing the high rpms make sense...(6 lug's 3.72)
    the 6 speed does take the cake at a 0.84:1
    i used to rev around 2K at 60 but not anymore....:(
  7. Dec 2, 2009 at 9:23 PM
    Tacoyota
    08 4wd
    my 6 lug is factory 4.1 axle.
    The .805 5th gear makes sense since I'm around 2400 in 5th but 3000 in 4th.
    4th is smooth though, you can forget you are in it on the freeway and not in 5th, a bit of a noisy interior doesnt help there.
  8. Dec 2, 2009 at 9:34 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    yes and with the 2TR you need those RPMs...i roll at around 1600 RPM at 55...hills suck...big time. i really need to regear:mad:
  9. Dec 2, 2009 at 9:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....For some reason I had it written down the 5 speeds had the same 5th ratio. But......the rear IS a 3.73 on the V6's ;)
  10. Dec 2, 2009 at 9:54 PM
    MEANGREENTACOMA09
    MEANGREENTACOMA09 Well-Known Member
    Memphis
    Timberland Mica 09 DBL CAB 4x4 TRD OFF ROAD
    TRD cat back exhaust, rain visors, limo tent on back pasenger windows and 35 percent added to back factory tint window. 35 on front driver and pasenger side. Sport pedals, all weather fl mats, roof rack, front skid plate , BFG ALL TERAINS including spare. ALL installed by dealer.
    That is way too high. I would have it checked. I have an Automatic and at 70 I am right at 2000 and at 75 it is like 2200-2300. Are you sure you have it all the way in sixth gear?
  11. Dec 2, 2009 at 9:55 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Different ratios for the Auto vs. Manual. The manual 6 speed WILL have the engine reving higher than the 5th gear in the auto.
  12. Dec 2, 2009 at 9:59 PM
    Tacoyota
    08 4wd
    Is it in "D" , or "3"?
  13. Dec 2, 2009 at 10:13 PM
    Kelson
    Kelson
    Honolulu, Hawaii
    sorry...
    3.727 ;);)
  14. Dec 2, 2009 at 10:15 PM
    VixTacom
    VixTacom SYC TACO
    Victor
    Wayne, NJ
    PreRunner SR5 TRD
    LED's and Neon Glow inside, Blacked out front end, 4X4 with Locking Diff, 5spd Manual, TRD package, CB Radio, Gray Wire Mod, Thrush exhaust system, Tinted marker lights, tailights, interior lights
    the trans is fine in my truck and the same thing happens. i thought it was a prob, so i had the trans checked and a new clutch put in. The truck ran the same...
  15. Feb 5, 2020 at 10:39 AM
    #35
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Hi guys, it’s an old thread I know but I wanted to let you k of this. I have an 05 Tundra with the 4.0 and 6MT. It has 245/70r16 tires and a 4.08 rear diff and it turns 2600rpms @65mph. Pretty high rpms and it is actually only rated for 5200lbs towing, compared to Tacoma’s 6500lbs.
