rpm question
Discussion in '1st Gen. Tacomas (1995-2004)' started by waldotoyota, Sep 7, 2016.
  1. Sep 7, 2016 at 10:39 PM
    waldotoyota
    waldotoyota [OP] Well-Known Member
    tanner
    Washington
    99 black TRD 4x4
    Hey everyone, been looking for a new Tacoma the past couple weeks and wanted to get a v6 5 speed this time. I finally found a 96 I like and test drove it, and it seemed like it was running a higher rpm than I would feel is normal. At 70 it was running at 3k or so. Do yours run about the same?
    I'm having the owner send me the gear ratio code in the morning but just curious what others are running on stock gearing. Thanks in advance
  2. Sep 8, 2016 at 3:02 AM
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    Look at code on door jam. Will tell you what gears truck has. Mine has 4.30 gears and at 70 mine is under 3k rpms. 4 cyl 5 speed
  3. Sep 8, 2016 at 8:10 AM
    waldotoyota
    tanner
    Washington
    99 black TRD 4x4
    ya my 4cyl 5 speed ran at like 2500 or less and my dads v6 auto runs at 2k, thats whats making me curious
  4. Sep 8, 2016 at 8:12 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    does it have bigger tires than stock?
  5. Sep 8, 2016 at 8:25 AM
    waldotoyota
    tanner
    Washington
    99 black TRD 4x4
    ya it has 32" and the guy said it has 4 10 gears. he hasnt sent me the sticker yet. but i dont think the speedo has been changed. i just feel like it would get crap gas milage.
  6. Sep 8, 2016 at 8:27 AM
    wilcam47
    Will
    Bourbon state
    sounds like he just put bigger tires on it...and not gears is why its pushing 3k RPM
  7. Sep 8, 2016 at 8:32 AM
    wilcam47
    Will
    Bourbon state
  8. Sep 8, 2016 at 9:27 AM
    waldotoyota
    tanner
    Washington
    99 black TRD 4x4
    if thats the case, why is my dads v6 auto running 2k on 31s,when the gear ratios are supposedly the same. the 5 speed must be geared lower
  9. Sep 8, 2016 at 10:32 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You have this backwards. Larger tires would mean lower rpms at a given speed.
    Two things can possibly explain those higher rpms. And the numbers you listed are definitely much higher than stock.
    If the truck has been re-geared to be able to run larger tires is the most likely possibility. Of course this would mean that the door sticker information would no longer be valid.
    The other thing that can make the rpms higher than stock, is if it has tires that are smaller in size from what it came with stock. But you said it had 32s on it so this is not the case. The largest tire from the factory was 31s. On the '96 model the 31s would have been 31x10.5r15s and most likely had 4.10 gears but some of those also came with 3.90 gears.
  10. Sep 8, 2016 at 11:56 AM
    waldotoyota
    tanner
    Washington
    99 black TRD 4x4
    that makes sense, thats the conclusion iv started to come to as well, maybe a good truck for 33s
  11. Sep 8, 2016 at 11:58 AM
    eon_blue
    Azusa, CA
    Sounds normal especially if it has larger than stock tires. My 3.4l 5speed 2004 is pushing just under 3k RPMs at 70mph. If you want decent MPG's, the sweet spot for highway driving is between 60-70 mph. I can do well over that no problem, but gas mileage takes a pretty big hit.
  12. Sep 8, 2016 at 12:04 PM
    waldotoyota
    tanner
    Washington
    99 black TRD 4x4
    sweet, thanks for the input
  13. Sep 8, 2016 at 12:09 PM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Bigger tires = more distance traveled per revolution = LOWER RPM at a given speed, assuming the speedo has been corrected. If you just install bigger tires, nothing will change with respect to indicated speed vs RPM although you will be traveling faster than you think.
  14. Sep 10, 2016 at 11:54 AM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    My idles with an 03 v6 (5vz-fe)
    cold:
    1100 in park
    800 in gear
    warm:
    750 in park
    500 in gear
    no stalls, thats just how my engine runs
