RPM question
Discussion in 'Towing' started by Rambleman, Nov 3, 2020.
  1. Nov 3, 2020 at 3:04 PM
    Rambleman
    Rambleman [OP] Member
    Robby
    2000 Tacoma trd
    i pulled my 198 v series skiff today and it pulled fine. My question is running at 65-70mph it was staying at almost 3000rpm. I will tow this boat up to 4 hrs one way about once-twice a year. Is that anything to be concerned about mechanically? I’m not worried about the fuel. 2014 4.0 v6 4wd
  2. Nov 3, 2020 at 6:13 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    You are fine. Assuming it’s an automatic just keep it in 4 not D while towing and the rpm’s are what they are. A lot of people get concerned about the rpm’s while towing in 4 but you shouldn’t be. Your owners manual tells you to tow in 4. You have nothing to be concerned about.
    Aquatic Tacoma likes this.
  3. Nov 3, 2020 at 7:15 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I’ve towed a 3300 lb travel trailer approx 10,000 miles. I’ve always followed the owners manual towing section Also have had my truck serviced per Owners Manual service requirements under “towing” requirements. Yes rpm level is concerning to me, even irritating. Also when I consider the 0 weight oil in these things. I’m old and have built many hp engines. 0 weight oil makes no sense to me except this vehicle was designed by automotive engineers which I am not.
  4. Nov 4, 2020 at 9:00 AM
    Toyotadilly
    Toyotadilly Well-Known Member
    Dillynn
    Sarasota,fl
    03 prerunner 2008 Toyota Sequoia limited w/tow package..01 echo 310k soon daily
    Bilstein 5100’s.eibach coils.stoptech cryogenic rotors.1.25in toytec blocks.tranmission cooler. Electric fan w/ relay.
    Ur good, are your tralior tires rated for 70mph? If ur auto a transmission cooler is always good. Mabye a ultra gauge or scan gauge to monitor transmission temps.
