RPM stuck on 3????
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taconator87, Jul 10, 2017.
  1. Jul 11, 2017 at 11:07 AM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Keep an eye on this... if it's just your instrument cluster or shifting business not a huge deal imo. If the RPMs were indeed acting that whacky, the crankshaft position sensor in these trucks has been giving a lot of us trouble though not sure if it would have impacted yours that seems would have been built ~2 years ago at this point. ...and there has been some anecdotal connections made between heat and sensor degradation.
    Is this really the only issue you're experiencing?
    What was your truck build date and location of build?
    How does it idle (and in what RPM range when warm and in Park)?
    What kind of MPGs are you getting combined (speeds 65 mph or less)?
    shakerhood likes this.
  2. Jul 11, 2017 at 11:12 AM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Damn, I thought I was going to get to the end without someone saying this.
    It definitely sounds like it downshifted for you to use engine braking. It's a known fact that it can and will do this. Furthermore everything you have said sounds completely reasonable for a downshift into engine braking. Just because the RPMs went up doesn't mean you are going to accelerate. Not understanding that is a result of never driving a manual me thinks. The auto only generation will soon be upon us..perhaps they already are.
  3. Jul 11, 2017 at 11:14 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Post #10 I mentioned engine braking as a possible suspect.
  4. Jul 11, 2017 at 11:15 AM
    bshammer0
    Brandon
    Nashville, TN
    This in bold is actually the one thing I'm starting to like about this auto tranny now that it seems to be behaving properly. I've never had an auto that would properly downshift when going down a hill to minimize braking. It's a great thing!
  5. Jul 11, 2017 at 11:25 AM
    Taconator87
    Taconator87 [OP] Well-Known Member
    Sounds reasonable.
  6. Jul 11, 2017 at 12:12 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    I've had the same issue multiple times... driving an incline down shifts to 4th in the 3k range and hangs in 4th longer than it should on the downside of the hill where I've noticed only tapping the gas peddle drops the rpm.
  7. Jul 11, 2017 at 12:39 PM
    Taconator87
    Well i guess this is normal. Thanks you sharing your experience.
  8. Jul 11, 2017 at 12:42 PM
    TacoRD16
    Houston, TX
    Like others have said since I've own manual vehicles I always figured it was a form of engine breaking. Even though I don't need any engine breaking on this truck with the lack of power to get back up to speed. Butt after owning a 86 samurai on 33" on stock gears this truck is fast lmao.
    Taconator87[OP] likes this.
