RPM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BR Pipke, Jan 12, 2017.
  1. Jan 12, 2017 at 3:38 AM
    BR Pipke
    BR Pipke [OP] Well-Known Member
    Drayton Valley Canada
    11 TRD short box 6speed std with 3" lift bilstein 5100 struts pro comp UCA AFE air cleaner and throttle spacer ultra rims 265-70/18 dual exhaust
    What rims are you doing when you're driving 100km or 62.5 mph with stock tires and 3:73 gears mine is 21-2200 is that high or normal? With the larger tires 265/70-18 I'm about 20-2100. I'm thinking of changing the gearing to 4:10. Is that gonna increase my rims when th the larger tires or keep it the same as the stock tires?
  2. Jan 12, 2017 at 4:41 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    16" rims, gearing won't change that. Lol. :anonymous:
    But sounds about normal, maybe a bit low. I'm running 265/75/16
  3. Jan 12, 2017 at 4:43 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  4. Jan 12, 2017 at 6:01 AM
    BR Pipke
    Stock size is 265/65-17 thx I'll check that out
