RPMs are revving high (video included)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by imDARRIN, Mar 26, 2013.
  1. Mar 26, 2013 at 9:56 AM
    imDARRIN
    imDARRIN [OP] Well-Known Member
    Darrin
    Huntington/Sunset Beach
    '13 PreRunner SR5
    I'm almost a week into having my new Taco and I've noticed that if my vehicle has been sitting and I start her up, the RPMs rev a lot higher when I have my truck in Park or in Neutral versus me having it in Drive or Reverse. Is this a natural response from the engine's computer taking control?
    2013 Tacoma Pre-Runner DCSB v6 4x2 sr5 automatic
    Apologies for being so GREEN concerning Tacomas, but this is the reason why I joined the forum; to seek knowledge and information from those of you who are willing to provide it. If you're simply feeling the need to tell me how absurd my question is or how I should already know the answer please move on to another thread. Thanks again.
    http://www.youtube.com/watch?v=JX8yJ4HRxnw
  2. Mar 26, 2013 at 10:03 AM
    Large
    Large Red
    Cold engine = higher RPMs in general until it warms up. Watched the vid a couple of times and looks normal to me
  3. Mar 26, 2013 at 10:09 AM
    imDARRIN
    Darrin
    '13 PreRunner SR5
    I wouldn't have posted a thread if I wasn't. 1st vehicle that isn't a pre1966 VW so I'm pretty unfamiliar with it..
    also 1st automatic
    "moving up in life"
  4. Mar 26, 2013 at 10:11 AM
    Aztecs
    Aztecs Well-Known Member
    Jose
    Tacoma, Washington
    2012 DCLB V6 4x4 SR5
    Debadge, Tailgate lock, 3" ProComp Suspension Lift, ProComp wheels and tires, Volant CAI with ram air scoop.
    What are your RPM's after it's all warmed up? But Yes cold starts do give High RPM's and your RPM's were gradualy going down as the engine was running.
  5. Mar 26, 2013 at 10:13 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    No load on a engine(neutral or park)= Higher RPM's. Load, (in gear)= lower RPM's. Just like any other automagic out there. Completely normal.
  6. Mar 26, 2013 at 10:13 AM
    Dark_Taco
    Dark_Taco ΜΟΛΩΝ ΛΑΒΕ
    08' TRD Rugged Trail Edition
    normal...no worries.
  7. Mar 26, 2013 at 10:16 AM
    Dark_Taco
    I was going to say the same thing...you beat me to it.
  8. Mar 26, 2013 at 10:19 AM
    Boone
    Boone, NC
    Airbags deployed
    I'm amazed. I generally lose those races.
  9. Mar 26, 2013 at 11:16 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
  10. Mar 26, 2013 at 12:42 PM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Normal for a cold engine.
  11. Mar 26, 2013 at 12:45 PM
    ouyin2000
    ouyin2000 Well-Known Member
    Arlington, Virginia
    '11 DCSB TRD Sport
    Leer 100XL Canopy, OEM Side steps, TRD Oil Cap, TRD License Plate Cover, WeatherTech Digital Fit Liners, Elite O/R Hitch Shackle, Katzkin Leather Interior, LED Interior Lighting, Foglight Anytime mod, Illuminated 4x4 switch, Grom Audio Aux adapter, Redline Goods leather shift boot console cover and door handle pulls, Sockmonkey bedside decals, Dynolock electric tailgate lock
    Welcome to the forum! Don't let these trolls stop you from asking questions. There is a lot of information on here, so feel free to browse away. Whenever I have a question, I like to spend a bit of time searching through seeing if it's been asked before, as there are some very knowledgeable people around here. And lots of issues have likely already been covered.
    Your issue is completely normal. It happens with the manual as well as with the auto trans.
  12. Mar 26, 2013 at 4:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    This ^^^^
    its totally normal.
  13. Mar 26, 2013 at 4:06 PM
    Large
    Large Red
    Not everyone are trolls, his concerns were addressed in the 1st post.
  14. Mar 26, 2013 at 4:10 PM
    Chris24
    Chris24 Well-Known Member
    Greensboro, NC
    09 Black DCSB TRD Sport, V6, 6sp
    Neutral and park, no load on engine, higher RPMS
  15. Mar 26, 2013 at 4:30 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2011 Double Cab V6 SR5 4x4
    N-fab steps, Emblem delete, Level 8 MK6 Wheels, TonnoPro, Foglight Anytime mod, DTRL Delete mod, Differential Breather mod. Window tint, Satoshi, Black-out interior pieces
    Mine does exactly the same thing. Worried me too at first.
  16. Mar 26, 2013 at 7:32 PM
    Mtn Tacoma
    Mtn Tacoma Dude
    Craig
    MI
    13 MGM AC OR
    As everyone has already mentioned this is definitely a normal operation. If you leave the vehicle in Park and let the engine warm up you can see the rpm's will ramp down to about 650 rpm (warm idle speed); it should take about 3-5 min depending on initial oil temperature. After warm up the Engine speed won't fluctuate as you operate the trans shifter.
    Also, there is no harm to change the shift lever to any position during that cold start but you may feel a little shift shock becuase the engine torque is higher compared to the warm idle case.
  17. Mar 26, 2013 at 8:33 PM
    maykevin5
    maykevin5 Well-Known Member
    Kevin
    Carbondale Illinois
    2012 Tacoma SR5
    3 inch lift, stainless steps, JL/Focal audio sound system
    I was used to GM but after buying my 2012 tacoma i've noticed some different things about the way toyota does things. Such as the high rpm when cold, no auto on headlights, doors relock after 30 seconds after unlocking with key fob and not opening the door. The big one that concerned me was that the fuel pump runs after 5 hours after turning the truck off to circulate the fuel in the lines to release pressure even with the key out of the ignition. Thought the fuel pump relay was stuck, then read the book and found it was normal... The oil drain plug gasket needs replaced every oil change, the heat exchanger for the oil filter and the coolant (that was odd at first and had to ask what that was) I thought it was a coolent filter... Spark plugs recommend changed at 30,000 GM vehicles says 100,000.. They still use a fan clutch and not electric fans.. Might have saved 1 or 2 mpg with electric but good ol fan clutch are bullet proof.
    Just some stuff to get used to.
  18. Mar 26, 2013 at 8:43 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    High rpm cold is so it warms up and iirc is better for emmisions...green
    my manual doors don't lock automatically
    sparkplugs are 120k on mine.. I got the I4, studying the truck before you buy it allows you to not get surprises. That's normal too.
    Clutch fans still work well, electric fans don't prove something modern or better.
    Some people not getting self informed before any brand of vehicle purchase.... normal.:)
  19. Mar 26, 2013 at 8:45 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    A pre-66 vw has a high idle on cold start too.
  20. Mar 26, 2013 at 8:59 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Kinda.
    You can leave them on 24/7. Shut the truck off, and when you open the door, the lights go out.
    It's an anti-theft feature. There are only so many codes. In a metropolitan area, it is quite likely that someone else in "your" parking lot may have the same code.
    They unlock their vehicle (and yours), get into theirs, and drive off.
    Yours is now unlocked and unattended. This feature fixes that.
    Just buy a Fumoto drain valve and never replace the gasket again.
    4.0 uses copper and change at 30k.... they're $3 plugs.
    The 2.7 and GM use Iridium plugs at 100k... $17 plugs.
    Same overall cost.
