RPM's at 65 MPH????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 90YotaPU, Sep 24, 2010.
  1. Sep 24, 2010 at 8:54 AM
    90YotaPU
    90YotaPU [OP] The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    Just curious. I have a 2010 4 cylinder regular cab 4x4 with the 5-speed. My RPM's at 65 seem high, around 2,300. Just curious what others are seeing.
    Thanks.
  2. Sep 24, 2010 at 8:58 AM
    remdawg
    remdawg Active Member
    I have a 4 cyl auto and I usually am around 2000 for 65, and 2200 for 70mph.
    This is with secondary filter removed and an AFE Pro-Dry.
  3. Sep 24, 2010 at 8:59 AM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    STi Short Shifter.OEM floor illumination kit. Rally Armor Mud Flaps. BC BR Coilovers. Invidia N1 Exhaust
    v6
    2200 65, 2700-3000 (depending on where im driving) for 75
  4. Sep 24, 2010 at 9:49 AM
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    if its an auto i assume its 2wd right? 2wd have the lower gear ratio so that sounds about rate.
    2300 at 65 sounds about right, the 4x4 2.7s have the 4.10 rear ratio
  5. Sep 24, 2010 at 10:05 AM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    your good!
  6. Sep 24, 2010 at 3:38 PM
    JB3CK24
    JB3CK24 Return to the 36 Chambers
    Jeff
    SD, CA
    2001 4x4 TRD, 2003 BMW 330i ZHP
    Mine is right at 1950-2000 at 65 mph.. 4.0L w/ 5 spd Auto.
  7. Sep 24, 2010 at 3:38 PM
    Twiget
    Twiget Proud to be Awesome
    America's Vancouver
    654, 6 Cylinders, 5 Speeds, 4 wheel drive
    Alpine Headunit, Soft Tonneau Cover, CAI
    Here is a calculator that will let you calculate what your RPM's should be at a given speed: Calculator
  8. Sep 24, 2010 at 4:04 PM
    BWro
    BWro Well-Known Member
    22-2300 @ 65 4.0, 6 speed 4x4
  9. Sep 24, 2010 at 5:54 PM
    THXEY
    THXEY Panda Jerk
    Jacob
    San Diego
    2013 Subaru WRX
    maybe not. i dont go on freeways too often to really notice. everywhere i go is decently close
  10. Sep 24, 2010 at 6:51 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    My 2009 was the same. That is normal. The auto's and 2wds run taller gears / lower rpm.
  11. Sep 24, 2010 at 6:53 PM
    Isthatahemi
    TRD OFF ROAD
    Air filters do not affect what rpm the engine cruises at.
