RPMS at what speeds?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruizbau2699, May 23, 2018.
  1. May 23, 2018 at 4:20 PM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    5th is overdrive on the 5M.
  2. May 23, 2018 at 4:22 PM
    Ruizbau2699
    Ruizbau2699 [OP] Well-Known Member
    Noe
    Easley South Carolina
    2018+1999 Tacoma TRD OFF-ROAD
    Ohh ok and I’ve checked speed on one of those speed monitors and it’s only like 1 or 2 mph off
  3. May 23, 2018 at 4:32 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    So your indicated speed is right.
    You just need to find out why the RPMs are so high.
    When you’re in 4th or 5th, what happens when you floor it? If the RPMs go up and your speed doesn’t increase, your clutch is slipping.
  4. May 23, 2018 at 4:38 PM
    Ruizbau2699
    Noe
    When I floor it in 4 th and 5th she’ll speed up
  5. May 23, 2018 at 4:59 PM
    Joe_from_iowa
    Joe_from_iowa Well-Known Member
    Joe
    2001 Tacoma TRD
    Maybe the transfer case is in low range...
  6. May 23, 2018 at 5:02 PM
    Ruizbau2699
    Noe
    You mean like 4 low?
  7. May 23, 2018 at 5:02 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    No. It’s 2.28:1 and 70 mph wouldn’t be possible.
    Running Board Man likes this.
  8. May 23, 2018 at 7:03 PM
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    That was kinda my thought too, but idk if you could go that fast in 4lo even in 5th without being on rev limiter.
    How are you sure it has 4.10's? Just by the door code sticker? Or actually counting spins of the driveshaft? Has the truck always done this or is it a new issue?
    Basically what I see, is either the tach is off (doubtful because you said the motor is screaming) the clutch I wouldn't think is slipping because you'd smell it and it'd burn up in a few miles as people have already said. So you take those two things out, and being a stock 5spd with 4.10's it's impossible for it to be doing that rpm at that speed. Either you're not in 5th or the truck has been regeared to a lower, numerically higher rear end
  9. May 23, 2018 at 7:10 PM
    eon_blue
    Azusa, CA
    No way you could hit 70mph in 4lo lol...I think I've gotten up to 40 mph in 4lo and 5th and was pushing 4k rpms. I dunno maybe it's possible but I feel like you'd definitely know it
  10. May 23, 2018 at 7:11 PM
    E30325
    Nick
    I agree
  11. May 23, 2018 at 7:14 PM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Yep, I didn’t like going 35 in low range / 5th. It’s eqivalent to 80+ in high range.
  12. May 23, 2018 at 7:23 PM
    Clearwater Bill
    Billy
    Largo Florida
    gmr102 likes this.
  13. May 23, 2018 at 7:39 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Is that gauge cluster from a 4 cylinder by any chance?
  14. May 23, 2018 at 8:07 PM
    Ruizbau2699
    Noe
    I know it’s a 4:10 bc I got the rear axle and front diff out of a newer 1st gen Tacoma and swapped both with mine and the sticker on that truck was 4:10 I don’t think it had been regeared before I pulled it bc the donor truck was bone stock but i haven’t really checked but I’m sure I’m in 5th gear believe me I know I am
  15. May 23, 2018 at 8:07 PM
    #35
    Ruizbau2699
    Noe
    No it was the v6
  16. May 23, 2018 at 8:09 PM
    #36
    Ruizbau2699
    Noe
    Yep I’ve done this before bc when I bought my truck the previous owner had two different front and rear gear ratios
  17. May 23, 2018 at 8:19 PM
    #37
    E30325
    Nick
    What was your cruising RPM like before you swapped them? Given the info I'd say the new ones you swapped in must be a lower ratio. Because if it's a v6 cluster that is reading correct, and you're in 5th, is impossible to be doing that RPM. It would be really weird if you got diff's out of a stock truck that were regeared lower, but that's the only thing that makes sense to me.
  18. May 23, 2018 at 8:26 PM
    #38
    Ruizbau2699
    Noe
    Well the first rear axle was 4:30 with with something else in the front I can’t really remember how it crused but I know that a buddy of mine that has practically the same truck except 98 pointed it out while he drove it that it reved high while cruising doing like 60 to 70 when he’s truck was a lot smoother and lower rpms then I put a temporary 4:10 bc the other rear end had bad seals and it felt a little different not a whole lot but it’s been the same since i swapped both front and rear
  19. May 23, 2018 at 8:41 PM
    #39
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    It really sounds like your rear diff is not 4.10.
    E30325 and cruxofthebisquit like this.
  20. May 23, 2018 at 9:42 PM
    #40
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    I have 4.10 gears and 5 speed manual with 31" tires and my tach reads exactly 2500 RPM at 70 MPH.
    E30325 and Running Board Man like this.
