RPMS at what speeds?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruizbau2699, May 23, 2018.
  1. May 23, 2018 at 9:44 PM
    #41
    E30325
    E30325 Well-Known Member
    Nick
    2000 Tacoma TRD 5spd
    5100's and OME 881's, AAL and KM3's
    Yeah I wouldn't expect much difference at all between 4.10 and 4.30's, my truck is 4.10's 5spd on 31's and to get the rpm's you're saying I think I'd have to be in the 4.88-5.29 range. Way low gears
    Running Board Man likes this.
  2. May 23, 2018 at 9:46 PM
    #42
    E30325
    Nick
    Even if he had a broken shaft with say a spooled rear end it shouldn't affect RPM, and it would drive like absolute butthole I would think
  3. May 23, 2018 at 9:55 PM
    #43
    E30325
    Nick
    Yeah that makes more sense, for some reason my mind just went to a spool or locker and totally forgot about LSD's
  4. May 24, 2018 at 3:07 AM
    #44
    Ruizbau2699
    Ruizbau2699 [OP] Well-Known Member
    Noe
    Easley South Carolina
    2018+1999 Tacoma TRD OFF-ROAD
    I’ll have to check it today after work and make sure that might be the problem idk
  5. May 24, 2018 at 3:10 AM
    #45
    Ruizbau2699
    Noe
    They’re pretty high in 3rd I’ll be at 40-45 doing like 3500k or 4 rpms and in 4th I’ll be doing 50 at about 3k rpms
  6. May 24, 2018 at 4:26 AM
    #46
    Clearwater Bill
    Billy
    Largo Florida
    Look at the tire calculator for your size tires, at the bottom of the page, where it shows RPM and gear ratios
    https://www.tacomaworld.com/tirecalc?tires=265-75r16
    So you have options to explore..........
    1) your final gear is over 5.xx
    2) your speedo is reading way low (GPS verified?)
    3) your tach is reading way high (you did a cluster swap. But you also say the engine is screaming)
    4) you're not in 5th gear
    5) there is massive clutch slippage
  7. May 24, 2018 at 9:55 AM
    #47
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Yea, I doubt it's clutch, he's not complaining about it slipping 1-2 or 2-3. That's where it really shows itself.
    Unlikely he got hold of a 5:something matching set of diffs. and not be aware, esp. from a stock donor.
    Pretty sure he would know he had another gear if in 4th.
    This all leads me to thinking the tach is not reading right.
    Is there a click switch behind these to change signal from 4 to 6 cyl.?
    OP do you have access to a scanner to verify RPM?
    E30325 likes this.
  8. May 24, 2018 at 10:10 AM
    #48
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    A slipping clutch will show itself in the higher gears because in lower gears it’s easier for the engine to move the truck.
  9. May 24, 2018 at 11:17 AM
    #49
    E30325
    Nick
    True, this would be exactly how it would act, but it would smell awful and wouldn't last more then a few minutes if it was being held there slipping while driving.
    What's the tach read at idle? Stand on it in neutral till it hits rev limiter and see what it says for RPM, haha not the best approach but it would let you know if it's accurate
  10. May 24, 2018 at 11:27 AM
    #50
    cruisedon66
    cruisedon66 Well-Known Member
    Pete
    Near St. Louis
    2003 Tacoma Extra Cab 2WD A/T
    Defrost mirrors, compass/temp display rear view mirror, rear wiper on camper shell, trans.cooler.
  11. May 24, 2018 at 1:56 PM
    #51
    Ruizbau2699
    Noe
    Nope don’t smell a thing
  12. May 24, 2018 at 1:57 PM
    #52
    Ruizbau2699
    Noe
    No i don’t think so but i got it off a v6 truck just a auto
  13. May 24, 2018 at 1:58 PM
    #53
    Ruizbau2699
    Noe
    It reads 1k at idle and idk about hitting rev limiter
  14. May 24, 2018 at 8:27 PM
    #54
    cruxofthebisquit
    Orange Texas
    2000 TRD
    welp, I'm out:notsure:, you won't hurt anything trying the top though to see if it 1) bounces around 5500 or 2) goes to 8000, in which case, it's your tach.
    If it's not your tach, I guess you have 5:30 gears.
  15. May 24, 2018 at 8:54 PM
    #55
    E30325
    Nick
    Agree. Would be so weird and random to get 5.29 thirds out of a stock donor truck haha.. its gotta be the tach though, I feel like you'd know if you had 5.29's, it'd burn tires through the first three gears :burnrubber:
  16. May 24, 2018 at 9:04 PM
    #56
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Yeah, there may be a compatibility issue between the V6 and 4 cylinder tach.
    Can you test the tach against a scan gauge or ultra gauge?
    Clearwater Bill likes this.
  17. May 25, 2018 at 2:33 AM
    #57
    Ruizbau2699
    Noe
    But it came off another v6 truck and it did it even with the stock gauge cluster
    And I did the GPS Mph and it’s accurate so I think the tach is fine
  18. May 25, 2018 at 7:30 AM
    #58
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Yeah, the speedo is good but it’s a different signal from the tach.
  19. May 25, 2018 at 7:30 AM
    #59
    cruxofthebisquit
    Orange Texas
    2000 TRD
    speedometer and tach are driven from two different sources but if it did the same with your old one it doesn't make sense again.
    You would really have to check it with a scan. Although if the ECU thinks that what it's spinning I guess everything will always show that way. I guess.
    Whatever is going on, to answer your original question, no one else with the exact same set up carries that many revs down the hwy. I carry about 3 grand at close to 80 and mine GPS's correct now with 265/75/16's.
    Clearwater Bill and black coffee like this.
  20. May 26, 2018 at 6:10 AM
    #60
    Ruizbau2699
    Noe
    Still don’t know gonna check my gear ratio once I get home today
