RPMS at what speeds?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ruizbau2699, May 23, 2018.
  1. May 27, 2018 at 7:48 PM
    #61
    Ruizbau2699
    Ruizbau2699 [OP] Well-Known Member
    Noe
    Easley South Carolina
    2018+1999 Tacoma TRD OFF-ROAD
    I’ll try and get one tomorrow
  2. May 27, 2018 at 7:49 PM
    #62
    Ruizbau2699
    Noe
    But do y’all think it could be some kind of sensor problem? Or trans problem or something else besides the ratio and axle
  3. May 27, 2018 at 7:51 PM
    #63
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    Doesn’t sound like a transmission problem to me.
  4. May 29, 2018 at 4:28 AM
    #64
    Clearwater Bill
    Billy
    Largo Florida
    And the answer is??
  5. May 29, 2018 at 9:24 AM
    #65
    Ruizbau2699
    Noe
    It’s been raining like hell here where I live and I’ve been getting off late haven’t been able to do it but I was told I had to pull the hog head off to check
  6. May 29, 2018 at 9:56 AM
    #66
    Clearwater Bill
    Billy
    Largo Florida
    No reason to take anything apart. Follow the procedure in the link in post 44 and you'll be 'close enough'.
    Take your time, be precise, double check the procedure and your markings. Wouldn't even be bad to have a friend watch/count one component while you do the other.
  7. Jun 3, 2018 at 11:58 AM
    #67
    Ruizbau2699
    Noe
    I have a video of it running on the Hwy but I can’t post it on here it won’t let me
  8. Jun 3, 2018 at 12:08 PM
    #68
    eon_blue
    Azusa, CA
    You have to upload it to a video hosting site like YouTube and then post the link.
    Running Board Man likes this.
  9. Jun 3, 2018 at 12:14 PM
    #69
    Ruizbau2699
    Noe
    Alright thanks
  10. Jun 3, 2018 at 12:15 PM
    #70
    Ruizbau2699
    Noe
  11. Jun 3, 2018 at 12:57 PM
    #71
    Clearwater Bill
    Billy
    Largo Florida
    Ok.
    But what are the results of the test from the link in post 44?
  12. Jun 3, 2018 at 1:07 PM
    #72
    Paul123
    Paul123 Web-Wheeler
    Paul
    Reno
    2014 TRDOR pyrite mica, 3" lift 33's, 4.56’s
    I’m gonna guess there’s some 4.88s in those axles
  13. Jun 3, 2018 at 1:19 PM
    #73
    Ruizbau2699
    Noe
    4:10 just did the test moments ago
  14. Jun 3, 2018 at 1:43 PM
    #74
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The photo is showing about 3750 rpm's @ about 68 mph, your larger tires mean your actual speed is 70-72 instead of 68.. Seems normal to me with that engine, and 4.10 gears.
    Different engines develop their torque at different speeds. My Tacoma with the 4.0 V6 will be around 2500 rpms at 70, my F-150 is closer to 2000 rpm's. But our Honda is doing 3500 rpm's when cruising at 70. It will often hit near 5000 rpm's when accelerating. Doesn't hurt a thing with any of them. The engines are just designed that way.
  15. Jun 3, 2018 at 1:51 PM
    #75
    Ruizbau2699
    Noe
    But other Tacoma’s like mine with same tire size same motor same gear ratio can do 70 at 2500 rpms and I’m at about 4000 rpms doing 70
    black coffee likes this.
  16. Jun 3, 2018 at 2:11 PM
    #76
    Ruizbau2699
    Noe
    I reckon I’ll have to get a gauge scan to know for sure what rpms I’m running
  17. Jun 3, 2018 at 2:14 PM
    #77
    Ruizbau2699
    Noe
    What kind do you have?
  18. Jun 3, 2018 at 2:27 PM
    #78
    Ruizbau2699
    Noe
    Thanks bud
  19. Jun 3, 2018 at 8:50 PM
    #79
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    Hurting, no. But running 4k rpm at 70mph is not normal. Even with the 5 spd it should be below 2700. with larger tires it would decrease that even a little more. for my auto I went from 2250 @ 31" to 2200 @ 32" tires for 70 mph.
    could be noise cancellation or adjustment from the phone's mic. it does sound like it's revving to me.
    @Ruizbau2699 have you looked at the clutch at all? is there any material even left? no material no smell? (forgive me if this was asked, I only looked so far back)
  20. Jun 7, 2018 at 11:44 AM
    #80
    Clearwater Bill
    Billy
    Largo Florida
    Looking forward to hearing the results of the gauge calibration testing.
    Because I still can't think of anything other than the list of options in post 62.
