Rpm's drop from 3000 to 100 and then back up to 3000 when at 30mph
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nbarker, Aug 13, 2012.
  1. Aug 13, 2012 at 3:53 PM
    nbarker
    nbarker [OP] New Member
    i have a 2007 access cab, 6cyl, at. when at approx 30 mph the rpm's will drop from 3000 to 100 then immediately back up to 3000.
    toyota charged me $350 for a complete tune-up and this did not help. they checked the pressure of the fuel pump and it was good and the fuel filter was clean. i'm not sure what to do? i find this to be a security issue. can anyone suggest what to look for or do?
    thank you in advance
  2. Aug 13, 2012 at 3:55 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    What the hell amounts to a tune-up nowadays anyway?
  3. Aug 13, 2012 at 5:17 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    you can also try cleaning that sensor with brakeclean or contact cleaner just do not touch the element with anything but the solvents
  4. Aug 13, 2012 at 5:38 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    (IAC) Idle Air Control Valve possibly.
  5. Aug 15, 2012 at 3:10 PM
    nbarker
    Thanks going to pass that on to my neighbor friend who is having this problem with his 07 taco. I'll post an update when he gives me one.
  6. Aug 15, 2012 at 3:16 PM
    Nathan88
    Nathan88 Member
    Nathan
    Ga
    06 PreRunner SR5 TRD Sport
    DoubleDin Pioneer P3200 dvd headunit, Big Country chrome side step bars, 25% tint windows, Bak rollbak bed cover.
    If you are going to spray the MAF use ONLY MAF cleaner, do not touch the spray nozzle on the sensor wires or you will have to buy a new MAF. I agree with JimmyH, you may need to clean the Idle air control valve. Sometimes they stick and will cause your engine to stall. I don't know what all was done in your tune up but you may also want to try cleaning the throttle body as well when your air filter was changed, it never hurts to clean the throttle body during a tune up =) hope this helps some.
