RPMs Jump to 1200 at start - 2012 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRDHUNTR, Feb 27, 2012.
  1. Feb 27, 2012 at 9:51 PM
    TRDHUNTR
    TRDHUNTR [OP] Active Member
    Hey guys,
    Question - Every time I start my truck in the morning, my RPMs jump and stay steady at 1200 RPMs when its still in park. It will not level back to 800-900 until I put it in drive. Happens also in evening when I leave work and truck has been parked for 9 hours. Temp is around 55 degrees in morning.
    Is this normal and does this happen to anyone else?
    TY
  2. Feb 27, 2012 at 10:37 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    My 4runner used to do this and it was normal. Would rev a little high and then settle down when warm.
  3. Feb 27, 2012 at 10:41 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Open loop operation
  4. Feb 27, 2012 at 10:42 PM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    My 1st gen does that it's just normal operation I believe, but you can check your owners manual and it will tell you.
  5. Feb 27, 2012 at 10:45 PM
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    Is it supposed to be idling at 1200? Mine starts up at 1500 and drops to about 1100 or 1000 when I throw it in D.
  6. Feb 27, 2012 at 10:48 PM
    S7ICKlVlAN
    Dave
    Hawaii
    2012 TRD Sport DCSB
    It should idle above normal speed until pre-spec parameters are met. Usually your thermostat temp needs to be met, certain amount of time elapsed, or 02 sensors warm up. Then you go into closed loop which utilizes the 02's & MAF to keep you near stoichiometric 14.7:1 A/F.
  7. Feb 28, 2012 at 9:25 AM
    TRDHUNTR
    Wow, you know your stuff. Thanks guys for the response. It appears that the truck was engineered this way which is good to know.
  8. Feb 28, 2012 at 10:09 AM
    AlaskanTaco
    AlaskanTaco Well-Known Member
    Anchorage Alaska
    09 sr5 acc cab tacoma
    Every vehicle is engineered this way. It is warming up the cat, and pumping the cat full of air also so that it may convert co-co2 and hc-h2o. Ya, it has a secondary air pump to help do it too. :)
  9. Feb 28, 2012 at 10:48 AM
    neonlazer
    neonlazer Mechanically Goofy
    Lafayette, LA
    '23 DCSB 4x4 SR5
    My 12 did this off the lot..normal :)
  10. Feb 28, 2012 at 10:58 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Yes....every single vehicle made today.
