rpms low?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Oct 22, 2020.
  1. Oct 22, 2020 at 11:06 AM
    kiki111
    kiki111 [OP] MENTALLY DISTURBED MEMBER
    Tacoma 2.7L SR
    any one with a 3rd gen tacoma...complain about the idle @ stops or parked seems low? mines is about 600 rpms..no check engine light?
    also all is idling fine and it shakes a little...normal???
  2. Oct 22, 2020 at 11:09 AM
    Tacospike
    Two Trucks
    Seems normal
    tonered likes this.
  3. Oct 22, 2020 at 11:12 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Spot on.
    shakerhood and Tacospike like this.
  4. Oct 22, 2020 at 11:12 AM
    gluvva
    gluvva Well-Known Member
    2020 Tacoma TRD sport DCLB MGM
    normal i think.
  5. Oct 22, 2020 at 11:17 AM
    kiki111
    Tacoma 2.7L SR
    so I'm guessing we're all having the same problem... anyone ever thought of raising the RPMs..pros / cons
  6. Oct 22, 2020 at 11:18 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Gawd no. 600 is great, IMHO. I did lower the cold start RPMs though. 1,500+ was ridonk.
    OVT does smooth out the warm idle RPMs significantly.
    Tacospike likes this.
  7. Oct 22, 2020 at 11:21 AM
    Winch
    Winch Well-Known Member
    2019 TRD OR MT V6
    None yet
    600 on mine.
  8. Oct 22, 2020 at 11:21 AM
    gluvva
    I might not a mechanic or anything so a legitimate question... what would raising the RPM do while being idle?
    Chew likes this.
  9. Oct 22, 2020 at 11:21 AM
    kiki111
    Tacoma 2.7L SR
    my cold starts (in the morn) are about 1200 at first..but i was referring to raising rpms from 600 to like 700 at stops....
  10. Oct 22, 2020 at 11:22 AM
    kiki111
    Tacoma 2.7L SR
    stop the shaking or feeling like its gonna turn off....just a thought
  11. Oct 22, 2020 at 11:23 AM
    gluvva
    Hmmm.. mine idles the same as yours but never really felt any (significant) shaking or felt that engine would turn off.
  12. Oct 22, 2020 at 11:30 AM
    kiki111
    Tacoma 2.7L SR
    well.... it's not turning off but when the rpms are low sometimes it makes me think that. but it's idling fine and every once in awhile it does a rough shake...just ordered a blue driver so I'm going to see if any codes come up...maybe its just me..lol
    btw...by rough shake i mean i shakes a little more than idle...not the whole truck shaking...
  13. Oct 22, 2020 at 11:48 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Unless the RPMs dip during that shake, nothing wrong.
    There is a low RPM engine trouble code if you had issues with the idle.
    Load on the system can cause idle fluctuation like AC, power steering, etc.
  14. Oct 22, 2020 at 11:52 AM
    kiki111
    Tacoma 2.7L SR
    rpms only go down to 600's or so @ stops/parked..the only time i notice the extra shake..never @ higher rpms...
  15. Oct 22, 2020 at 12:18 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    On my 2020 v6 auto, rpm at idle in drive, or reverse is 600. In park 800. This is will a fully warmed-up motor.
  16. Oct 22, 2020 at 1:01 PM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    600rpm while in D and stopped is normal.
    What is "problem" that you feel you're having?
  17. Oct 22, 2020 at 1:05 PM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    It’s not a problem. It’s normal for almost any new vehicle. No point in idling at 1000 rpm if you don’t need to
    Chew likes this.
  18. Oct 22, 2020 at 1:14 PM
    kiki111
    Tacoma 2.7L SR
    the truck is working fine I was just questioning the 600 RPM.... besides that it shakes a little bit sometimes wanted to see if it was normal
  19. Oct 22, 2020 at 1:27 PM
    WZ00R2
    TN
    2020 Cement OR
    600 rpm idle is normal, shaking at idle is not.
    Junkhead likes this.
  20. Oct 22, 2020 at 1:42 PM
    kiki111
    Tacoma 2.7L SR
    once again....shaking is minimal but there.... that's why I was asking was 600 RPMs normal and that little shake normal some say yes some say no I guess I'll have to figure it out
