RPMs Shooting Up on Random Downhills
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RVA_Lip, Aug 21, 2023.
  1. Aug 21, 2023 at 12:24 PM
    RVA_Lip
    RVA_Lip [OP] Well-Known Member
    2019 Tacoma SR V6
    I’ve noticed in my 2019 SR5 automatic 6 cylinder that occasionally when I hit the brakes going downhill, my rpm’s will jump to 3K or slightly higher and the engine revs loudly. Not every time - only sometimes.
    I don’t have downhill assist and I’m not in S Mode, nor do I have ECT on. Just regular D. Most of these hills aren’t even that big or steep.
    I guess my concern is that it does this intermittently. If it was built in engine braking, wouldn’t it do it every time/consistently? It just randomly does this. Anything to be concerned about? Or is this normal?
  2. Aug 21, 2023 at 12:26 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    This is totally normal. I've noticed there isn't much rhyme or reason to the downshift and engine braking.
  3. Aug 21, 2023 at 12:26 PM
    Malvolio
    Malvolio free zip ties for Stun
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    I think that’s the programming. It’s not like that Chevy Celebrity that just hung out in overdrive when you sailed down the hills from your younger years. Probably for the better anyways; these brake rotors warp easily and have on older Tacomas too, so a bit of engine braking ain’t the worst thing.
    Canadian Caber likes this.
  4. Aug 21, 2023 at 12:27 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    it depends on how the AI-Shift is feeling that day. too bad they don't let us customize the parameters in the menu.
    MadJacks, whatstcp and Malvolio like this.
  5. Aug 21, 2023 at 12:29 PM
    Malvolio
    SoCal Dumbgeon
    2017 DCSB SR5 2WD
    Thankfully his name isn’t Hunter, Whitehead, Poole, or Kaminsky!
  6. Aug 21, 2023 at 12:44 PM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Normal, when I start cruising down a long steep winding hill with my truck in 6th gear, if I tap the brakes the truck automatically downshift's to 4th. This engine compression braking will bring the trucks speed more under control, so as not to ride the brakes all the time. Works well when towing a trailer. I sometimes wish my old tundra did it.
    RedWings44 likes this.
  7. Aug 21, 2023 at 12:52 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    If you have Cruise Control on and if the truck senses an increase in speed on a downgrade, it will downshift to stay within some close proximity of your set speed, resulting in a jump in RPMs.
    If you are braking to reduce speed your truck may also downshift to assist with braking.
    I don't know if the SR trim has the Clinometer. This may have some bearing on the occurrence of a downshift.
    In any case of the above situations, it's normal behavior.
  8. Aug 21, 2023 at 1:10 PM
    RVA_Lip
    2019 Tacoma SR V6
    It’s just odd because I go down the same hill(s) 5 to 7 times a week and it’ll only shoot up the RPMs maybe 1-2 times out of those trips. The inconsistency was what troubled me.
  9. Aug 21, 2023 at 4:47 PM
    CT Yankee
    CT
    Mine is inconsistent. Depends on my truck's payload at times, i.e. another passenger or something in the bed. I suspect that even a tailwind will trigger the downshift with cruise control on.
  10. Aug 21, 2023 at 5:00 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Could be low on transmission fluid, hence why the sporadic hill shifts when fluid level changes.
    Checking transmission fluid is not my strong area.
  11. Aug 21, 2023 at 5:03 PM
    zoo truck
    None
    Idk, every time I go down these same hills, and tap the brake in the same area at roughly the same speed, my truck will downshift to 4th every time. I think if your speed, and braking habits are inconsistent, so will the transmission's downshifting.
  12. Aug 21, 2023 at 5:43 PM
    RVA_Lip
    2019 Tacoma SR V6
    Gotcha. I don’t use cruise control. Who knows…
  13. Aug 21, 2023 at 5:45 PM
    RVA_Lip
    2019 Tacoma SR V6
    Gosh. I hope not. Just bought it a month ago and it’s a certified Toyota so supposedly was gone over with a fine tooth comb. Has a good warranty at least.
  14. Aug 22, 2023 at 3:44 AM
    Gfenza89
    Gfenza89 Well-Known Member
    2024 Tacoma SR5 4x4 DCSB
    These trucks have a mind of their own literally. The A.I can be moody some days my tacoma runs super smooth and feels peppy and other days it just feels sluggish like it doesn’t feel like being driven that day. Quirky ass vehicles. What your experiencing is normal mine does the same thing
    Canadian Caber and bkhlrTaco's like this.
  15. Aug 22, 2023 at 3:51 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I went from 1st gen to 3rd and 1st thing I noticed in winter was the truck takes over(ABS, Traction) on slick roads and it felt like I wasn't in control like with the 1st gen. I didn't like it and took some getting used to.
    Gfenza89[QUOTED] likes this.
  16. Aug 22, 2023 at 4:12 AM
    cropduster78
    cropduster78 Well-Known Member
    NW CT
    '17 DCLB SR5 White
    OV-TUNE 2.0, ADDED/REMOVED STUFF
    its normal
    switch into s-mode and upshift is what I do sometimes
    or hit the throttle will get you out of the hang up
  17. Aug 22, 2023 at 4:14 AM
    airforceb2cc
    Don
    KCMO
    They didn't check your transmission fluid level when certifying.
  18. Aug 22, 2023 at 4:30 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Definitely normal. I find it just depends on how hard I hit the brakes going down said hill. I found it occurring far more when I was in Colorado. I believe a light use or tap often triggered it more than firm presses on the brakes. I did it enough to feel natural when I was there. I'm sure it also has to factor in how quickly it detects you picking up speed with no throttle input combined with brake use. I've also driven other vehicles with this feature. A Jeep JL I drove in Maui comes to mind.
  19. Aug 22, 2023 at 5:10 AM
    RVA_Lip
    2019 Tacoma SR V6
    It does seem to happen mainly with the light tap of the brakes.
    Yea - my previous vehicle (2019 Honda Fit automatic CTV) did engine braking on its own every single time going down a steep hill. So that’s what I was accustomed to. Not this inconsistency.
  20. Aug 22, 2023 at 5:11 AM
    RVA_Lip
    2019 Tacoma SR V6
    Hmmm. I’ll have to look into it. I don’t know if this is a sealed one. I know those are hard to check.
