RPMs won't go higher than 3k
Discussion in '1st Gen. Tacomas (1995-2004)' started by Iagie00, Mar 18, 2023.
  1. Mar 18, 2023 at 10:40 PM
    Iagie00
    Iagie00 [OP] New Member
    Isaac
    2001 Toyota Tacoma Trd
    I’ve got a 2.7 4cyl. 2001 Tacoma.
    It’s got 400,000 miles reading. But it’s been rebuilt. My issue is that when pressing on the gas pedal to the floor, it’s doesn’t increase in rpm’s. It’s stays around 2-3 thousand rpm’s. It has new spark plugs and coils. Not sure what they did to the engine due to me getting the truck with no info. But any recommendations on what would cause that?
  2. Mar 18, 2023 at 11:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the plugs?
  3. Mar 19, 2023 at 1:12 AM
    Iagie00
    Isaac
    Less than 150 miles. Literally just changed them.
  4. Mar 19, 2023 at 1:17 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What other info do you have? Are there any codes? Does it remain consistently at that RPM or just when you give it the gas and it won't go any faster?
  5. Mar 19, 2023 at 3:45 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Welcome to the forum!!
    With no idea just what was done to the engine or Just how many miles ago this has happened.
    I have been told rebuilt means many different things to different people.
    You need to start with the basics If you have Air a leak down test if not a compression test.
    Botched Timing Chain job.
    Poor injectors or lack of fuel pressure .
    Lets hope you get lucky and it is simple.
    Any local friends that can help? Perhaps post in your regional forum and meet new Toyota addicted friends.
  6. Mar 19, 2023 at 4:16 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    There must be a reason why the computer will not allow full throttle. I would check all connections to all sensors like temp, RPM, MAF and absolute manifold pressure sensors. this would be a good start.
    I wouldn't fret about a botched timing chain just yet.
  7. Mar 19, 2023 at 5:20 AM
    Clearwater Bill
    Billy
    Largo Florida
    Need more background.
    Why not have the 'rebuilder' correct their problem?
  8. Mar 19, 2023 at 10:02 AM
    1997tacomav6
    Denver
    Could be a number of things but a bad camshaft sensor or crankshaft sensor or the connectors will do this or wire harness damage possibly cracked to these two sensors
    Steves104x4 likes this.
  9. Mar 19, 2023 at 10:04 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    What ignition coils are you using? Thanks!
    1997tacomav6[QUOTED] likes this.
  10. Mar 19, 2023 at 10:08 AM
    1997tacomav6
    Denver
    Myself?
    OEM!
    Steves104x4[QUOTED] likes this.
  11. Mar 19, 2023 at 10:09 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Not original 700k? Well done!
  12. Mar 19, 2023 at 10:11 AM
    1997tacomav6
    Denver
    OEM=original equipment manufacturer Coils and plugs wires
  13. Mar 19, 2023 at 10:13 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    You’re on the original 1997 coils? Wow. Edit: Holy shit
  14. Mar 19, 2023 at 10:16 AM
    1997tacomav6
    Denver
    Haha, no!
    I just replaced them 3 months ago
  15. Mar 19, 2023 at 10:18 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Whew!
  16. Mar 19, 2023 at 10:22 AM
    1997tacomav6
    Denver
    I had ONE go bad around 400k and replaced just that one.
    I replaced all of them just recently because the haltech wasn’t getting alone with them.
    the coils don’t necessary throw a code and fail in different ways like not working at higher rpm’s but work at lower rpm’s just fine
  17. Mar 19, 2023 at 10:29 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    After 13 years i replaced all the coils with Standard Ignition Blue Streak UF495 and omg, it’s a different animal. The idle is smooth as silk. Very impressed
  18. Mar 20, 2023 at 6:24 AM
    Jakuku Pahwheenis
    Jakuku Pahwheenis i provide useless forum contributions
    J Phoenix
    South Carolina
    2003 Xtracab 2.7L 3RZ-FE 4x4 manual 245K+ miles
    Check the throttle cable?
