RR DIff Lock and 6 inch lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tankoma04, Mar 9, 2010.
  1. Mar 9, 2010 at 7:08 PM
    Tankoma04
    Tankoma04 [OP] Member
    SoCal
    04 PreRunner
    3.5 inch Fabtech front lift & 2.5 inch lift rear
    M
  2. Mar 9, 2010 at 7:10 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    It means the Locker is not yet engaged...sometime's it takes a few for the gears to line up correctly. The light will be on when its engaged...not blinking :)
  3. Mar 9, 2010 at 7:30 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    best way to engage the locker is to press the button while at a dead stop, if it flashes crawl forward (under 5mph) while turning the wheel side to side until you hear the click of the actuator and the RR Diff light goes solid. If it stills flashes, put the truck in reverse and crawl back for a couple feet and it should lock.
    whatever you do, don't punch it or go above 5mph until the light goes solid...
  4. Mar 10, 2010 at 6:24 AM
    tacomaprerunner
    tacomaprerunner Dang liberals.
    1995 Ford F350 7.3L PowerStroke Diesel
    Yup, ColtsTRD and mikesdoublecab nailed it.
    I don't know anything about the 6 inch lift...but if you get it installed I'd love to see some pictures!
