RR Diff Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sarra, Sep 23, 2021.
  1. Sep 23, 2021 at 9:17 PM
    Sarra
    Sarra [OP] Well-Known Member
    2007 TRD Off Road 4.0 6MT
    None yet
    So, yes, I've read the manual, and did see the bit about only using the locker while going under 5mph in 4 Lo.
    But, I'm curious as to what logic happens when you're not in 4 Lo, and you poke the button. So, in 4 Hi, if you hit the button, does the brainbox just ignore the input besides flashing the locker display on the dash, until you drop into 4 Lo, then it locks the rear diff, or will the rear diff actually attempt to lock while in 4 Hi?
    I'm asking this because I'd like to know more about how the system, and the logic behind it, works.
  2. Sep 23, 2021 at 9:18 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    You get flashing lights telling you to press the button again to turn it off. That’s about it.
    I’ve accidentally hit it plenty of times. Especially when cleaning the interior, I get tons of angry lights when I start it the next time.
  3. Sep 23, 2021 at 9:20 PM
    Sarra
    None yet
    lol Angry dash is angry.
    Well, that's good to know. If you have it pressed, and do drop it into 4 Lo, will it automatically try locking the rear, or will it make you push the button to turn it off, then back on?
  4. Sep 23, 2021 at 9:20 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    What happens:
    Not a goddammed thing. Dummy light and that's it.
  5. Sep 23, 2021 at 9:24 PM
    plurpimpin
    PDX
    honestly not sure about that one. Could always try and find out.
  6. Sep 24, 2021 at 5:53 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    The switch basically sends a locker request signal to the 4wd ECU, the 4wd ECU then checks if the correct conditions are met before it will engage the locker. On a 4wd truck it will ignore the locker switch unless it's in 4 low, there's not really any way to "trick" it into engaging the locker in 2wd if that's what your asking.
