Rr Diff Lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gatortrades, Feb 9, 2007.
  1. Jul 20, 2007 at 6:06 AM
    flyman767
    flyman767 Well-Known Member
    Yes...it will work. The grey mod was for older Tacoma's and the new generation is the basically the same with the exception of different color wires to locate. __________________
  2. Jul 20, 2007 at 2:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    :thumbsup: the manual only says 5mph, more than likely for safety reasons. lock it in and take off. very fun, especially if you are in a field somewhere:D!!
  3. Jul 20, 2007 at 2:46 PM
    Map06TRD
    Map06TRD Well-Known Member
    gray wire mod dosent not work for the 05+'s
  4. Jul 20, 2007 at 4:23 PM
    gcwaterski
    gcwaterski Well-Known Member
    My little cousin has a little 1st gen. single cab 2wd- he has thrashed that thing for 200,000 miles with no problems. when the weather would get bad, or we would be going down a dirt road he would hit that diff. lock up, and drive fast as hell! Nothing has ever broken.:thumbsup:
  5. Jan 15, 2010 at 11:44 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Thanks for this ... do you know if anything has changed for the '09 and '10 4WD Tacomas to get the rear locker to work in H4 or H2?
  6. Jan 15, 2010 at 11:51 AM
    straycat241
    straycat241 maXXXed out mid travel
    paul
    PreRunner TRD off road 4x2
    airaid intake, jba headers, jba exhaust, DMZ enginecage, King 2.5 coilovers , 1.25camburg uca's, total chaos lca's, shock hoops with Icon 2.5 piggybacks, camburg 4.0 Spindles, Defined engineering SUA, King 2.5" Shocks w/Reservoir, King 2.5 Bumpstops,shocktacobumper,moto metal 951's, compartment locks, blackgrill,Glassworks fenders front and rear,ViS racing glass hood,PIAA 510s,hella 500's,black rebadge,fabtech spare tire holder,tailgate delete,mudflaps delete,cobra 19 ultra iii
    in pismo Iwas locked all the time the locker helps out so much on the sand it's amazing!! I tried driving around unlocked but its so easy for 1 wheel to loose traction and to bog the truck down and get stuck
  7. Jan 15, 2010 at 11:53 AM
    Chester
    Chester Well-Known Member
    Nor Cal
    07 Access Cab TRD-OR M-V6 4x4
    Rear Spring TSB,Locker Mod,In bed cargo lights,Fully de-badged,TRD Seat Covers,Trailer Harness Relocation,Painted wheels,Extra tie-downs,5100's,Biceman lighting,09 stereo with sirius & isimple ipod interface,Rear diff breather mod,K&N Air Filter
    no change DAve K,talked a guy through the mod on his 10,just make sure all you work is done properly,that is the biggest reason people have problems in his case the relay was no good.And some have gone 70+ with it lock so dont worry about speed.Just dont use it like a knucklehead and it will always work,I cruise with mine on no problems.
  8. Jan 15, 2010 at 5:47 PM
    David K
    Thanks Chester... After I asked this, I got to thinking that since mine has TRAC (limited slip action) all the time, there may be no big advantage to locking the rear in H4 or H2... Just thinking outloud.
  9. Jan 15, 2010 at 6:58 PM
    c0astie31
    c0astie31 TACO SUPREME
    Dennis
    Long Island ny
    2011 4Runner Trail Edition
    A LOT
    i have locked mine in 2wd and race the drag strip, i was doind 96 at the trap, so who ever said you can't go that fast is full of it.
  10. Jan 16, 2010 at 7:55 AM
    David K
    The key word is dragstrip (straight)... Cool that you got it moving that fast!
  11. Mar 26, 2014 at 6:46 PM
    trdtacomav6std
    trdtacomav6std Active Member
    texas
    03 sr5 trd 4x4 std
    Kn&n intake
    Thanks this link was awesome easy instructions ... now I can operate diff lock in h2 and h4...
  12. Mar 26, 2014 at 6:51 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    I keep mine locked when doing high speed off road stuff (for better traction). It performs great! Been doing this for a few years now and no problems. I change my rear diff fluid a couple times a year too and have never found shavings or debris in the fluid. :)
  13. Nov 1, 2014 at 5:34 AM
    asipo123
    asipo123 New Member
    steve
    lexington ky
    hello every one i am new posting and could not find a new thread but only a reply . i just bought 06 thurs and love it has the off road package with the locking diff. well i read in the manual you stop truck and enage wait til the system locks in and the light goes to solid from flashing but it does not quit flashing whats the problem? thanks for your help. steve
  14. Dec 17, 2014 at 7:16 PM
    07terry
    07terry Active Member
    north carolina
    07 4x4 trd
    :(:(:(:(:( also when i reverse the two it turns in opposite direction ?
  15. Dec 17, 2014 at 7:27 PM
    #35
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    If the light won't go solid, take your foot off the brake and turn the steering wheel right or left.
    What you are doing by that is aligning the rear axles and you should hear and feel it lock up.
  16. Apr 25, 2015 at 4:41 PM
    #36
    TroutsTaco07
    TroutsTaco07 Active Member
    Dallas, TX
    07 TRD Off Road 4x4
    The sticker on the panel by my door handle says "operate diff lock at speeds below 5mph"
    I don't think I'll be baja-ing with mine on lol.
  17. Sep 3, 2015 at 11:40 AM
    #37
    T@codawg
    T@codawg Well-Known Member
    Mark
    Nashville
    99 TRD PreRunner Xtra Cab
    Full OME 881's w/nitros & Dakar leafs in rear
    I know this thread has been around awhile but I was glad to find it. I was a little concerned about driving to work at 5 mph on the nasty days. Nashville only has maybe a dozen bad days year in the worst years. One or two in a good year.
  18. Sep 3, 2015 at 12:20 PM
    #38
    Mavrick
    Mavrick Well-Known Member
    2015 DCSBOR
    You can go as fast as you want, just don't turn unless your driving on slippery ground so the inside back wheel can slip.
    T@codawg likes this.
