RR DIFF not engaging
Discussion in 'Technical Chat' started by willie64, Mar 25, 2013.
  1. Mar 25, 2013 at 11:59 AM
    willie64
    willie64 [OP] Willie64
    willie64
    BEND OR
    (slowly becoming less than) Stock '03 3.4L 4x4 TRD SR5
    144 watt led lights on front 36 watts x2 led on the back, cb, Kenwood ham, icon 3" lift, 285/75/16 Fierce Attitude tires, JoeZilla sliders, 4x innovation bumper. On the workbench: snorkel, new leaf springs, winch and bumper.
    03 TRD 3.4
    :help:went to play in the snow this w/e and pressed my Rear Diff lock button and it just blinked at me mockingly. Backed up about .25 mile, drove forward, backed up, drove forward, etc. Finally gave up. I checked all connections and everything seems to be in place and in working order. Any suggestions?:notsure:
  2. Mar 25, 2013 at 12:28 PM
    willie64
    willie64
    BEND OR
    Honestly, I can't tell. I can't feel any difference. The light just blinks, and blinks and blinks and blinks..........
  3. Mar 25, 2013 at 12:50 PM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Try turning? I always come to a complete stop, hit the button, then drive forward and turn back and Forth a little bit and hear it snap into place
  4. Mar 25, 2013 at 1:04 PM
    willie64
    willie64
    BEND OR
    OKTHIS sounds more encouraging that PSU's response. :D I'll try that second. I would hate for actuator to be fried. What's up with the turning bit? Is the system hooked up to the steering?
  5. Mar 25, 2013 at 1:41 PM
    VolcomTacoma
    Jeff
    NorCal
    Yea but hitting a button and moving back and forth for a few feet is way less work :)
    But yea, like someone said above, the way I remember it is the wheels moving at different speeds or whatever allows it to lock into place. I used to just hit the button and drive on and just see it blinking...and it took a while before I realized it was when I was barely moving and turning that I'd hear it snap in. So my way works every time for me :)
  6. Mar 25, 2013 at 1:57 PM
    David K
    David K Well-Known Member
    San Marcos, Alta California
    2010 4WD Off Road DC
    Differential Breather Mod Light Bar: 2 Hella 4000 HID, 1 Cibie Halogen. Bilstein 5100s Ride Rite Air Bags
    1) Have you ever used it before and know it worked?
    2) Are you in LOW RANGE? (Have you been in low range before?)
    3) From a stop, press the RR button (in L4) and note light blinks until it engages and goes solid... Begin to drive slowly... if still blinking turn your wheel all the way ONE direction, not back and forth and roll that direction. The light should go solid. Remember, using the rear locker is for emergencies only to get through an area or obstacle. Turning is more difficult if the tires cannot rotate independently.
  7. Mar 25, 2013 at 1:57 PM
    willie64
    willie64
    BEND OR
    however, I never tried turning. AND, that .25 mile may have been a bit of an exageration; maybe it was more like 50 ft.
    If the turning doesn't work I will take stuff apart. That's always fun, too.
  8. Mar 25, 2013 at 1:58 PM
    BulletToothTony
    BulletToothTony Wheres Francis?
    You can call me Susan if it makes you happy.
    Were you in 4lo?
  9. Mar 25, 2013 at 1:59 PM
    willie64
    willie64
    BEND OR
    Yep, used this a few times before with no issues, just clicked right in.
  10. Mar 25, 2013 at 2:02 PM
    willie64
    willie64
    BEND OR
    never used in 4lo. IDK, isn't that redundant? I've used when in 2hi and 4hi. each time the light flashed for a moment then went solid.
  11. Mar 25, 2013 at 2:09 PM
    BulletToothTony
    So you've done the locker mod?
  12. Mar 25, 2013 at 2:10 PM
    VolcomTacoma
    Jeff
    NorCal
    Also, roll your window down, turn the music down, when you try my way, you will definitely hear it *CLACK* into place
  13. Mar 25, 2013 at 2:12 PM
    VolcomTacoma
    Jeff
    NorCal
    Thought I broke something the first time I did it :) honestly my first two times offloading on my own, I probably only got it to pop in place on accident. Just hit the button, assumed it was on...and then probably stopped to take a photo or something and turned a little as I was starting again and it popped into place.
  14. Mar 25, 2013 at 2:13 PM
    David K
    Stock 4WD Tacomas can only use the locker when in Low Range 4WD. Otherwise, you have done a mod (Gray Wire?)... or a previous owner did.
    2WD Off Road PreRunners have a locker that works in 2WD...
  15. Mar 25, 2013 at 3:22 PM
    willie64
    willie64
    BEND OR
    All great input from every one.
    Being rather new to the sport (still learning and getting schooled :D) I am gathering that when I pushed the button in 2hi and 4hi (even though the ligh stayed on) I was not actually engaged. I was thinking about doing the grey wire mod but haven't done it..... yet. There aren't many justifiable reasons to do this in Portland.
  16. Mar 25, 2013 at 6:06 PM
    David K
    Willie, if it is locked, it will be VERY easily noticed... try parallel parking (or turning sharp while moving slow). The back tires will skuff... if locked. More so than the binding you feel when trying to turn sharply while in 4WD, on hard surfaces.
  17. Mar 26, 2013 at 11:04 AM
    willie64
    willie64
    BEND OR
    So, thanks again for all the input. I tried again last night after work (don't tell my boss I'm doing this on company time) and ripped up the yard, and part of my neighbor's.
    CLUNK!:headbang: it seems that just turning the steering wheel to hard left/ right is the ticket to success.
    Now, I guess it's time to do the gray wire mod.
    Thanks again for all the help.
  18. Mar 26, 2013 at 11:05 AM
    BulletToothTony
  19. Mar 26, 2013 at 11:05 AM
    VolcomTacoma
    Jeff
    NorCal
    What it is- you need to get your rear wheels to turn at different speeds. So just turning the wheel wont do much, gotta actually get your truck turning and those rear wheels moving, ya know? ;) Glad it worked out for ya!
  20. Mar 26, 2013 at 11:37 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    find a dirt road to engage and disengage that sucker in 4lo about 20 times
    and go back and do it the next week
    eventually it should loosen up and engage faster
    this procedure is what sometimes needs to be done on brand new
    4runners/tacos...I don't know if it helps a really old one
    my 4runner brand new in 1998 hated the locker and took
    a lot of tweaking to get it to 'klang' locked
    after using it a lot for a month, it became very smooth
    and reliable. still sometimes it won't engage right away, but
    instead of having to fight it, I only go from d-n-r-n-d
    and during that maybe move an inch and it will find the sweet spot
    and engage. if I pre-engage it (10 feet before i need it) 100% the time
    it will lock
