RRW RR5-S 17x8.5 -12 offset on stock 2nd gen Tacoma
Discussion in 'Wheels & Tires' started by 12Tako, Jan 30, 2025.
  1. Jan 30, 2025 at 11:25 PM
    12Tako
    12Tako [OP] Member
    Manoa
    2012 Tacoma DCSB V6 TRD Sport 4x4
    Hi,
    I'm fixing to replace my current wheels to the machined look. My Tacoma Sport 4dr 4wd is stock height, the wheels I'm interested in is RR5-S 17x8.5 -12 OS 4.28 BS. Before pulling the trigger, I messaged RRW via IG for confirmation on fitment - they responded with, "I believe the offset will not work" with my generation. I have seen all kinds of negative offset wheels on stock 2nd gens and I'm thinking their response is for liability reasons which is understandable. So my question to you folks, do you think the wheel with a -12 offset work on my stock height Tacoma? What kind of issues I might be faced with? I plan to keep it stock height, but if needed, I'm okay with leveling and/or doing some trimming etc. if needed.
    Regards,
    Sean
  2. Jan 31, 2025 at 1:51 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
    I ran my SCS Ray 10 with -10 OS stock with 265 70 17, I did get a wheel alignment and have them push the wheel forward whatever the stock setup allows. If something rubs it’ll be minimal, you might have to unbolt your front mudflaps.
  3. Jan 31, 2025 at 12:15 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Sean,
    Let me help out with some sound advice. As Dave noted, you should be able to run that wheel setup with 265/70/17 tires. All you will have to do is remove the front mud flaps and do some light liner trimming. Once everything is on the car, turn the wheels to full lock and you'll see where it's going to slightly rub on the liner. Simply trim that area out and call it a day.
    It will be similar to this here,
    https://www.tacomaworld.com/threads/front-wheel-well-trimming.46280/
    DavesTaco68 likes this.
  4. Mar 1, 2025 at 3:35 PM
    12Tako
    12Tako [OP] Member
    Manoa
    Thanks Vin, appreciate the help. I pulled the trigger on your FA16's. Awaiting delivery and installation.
